orientation of tubular UCAs #1190321
03/03/12 02:13 PM
03/03/12 02:13 PM
Keizer, Oregon
Dadrules Offline OP
Dadrules  Offline OP
Keizer, Oregon
long story short, I've been away from working on our 65 Barracuda for a couple of years. I'm now finishing up the front end, electrical etc. I installed tubular UCAs from firmfeel and want to double check that I'm installed them correctly. How can i tell which side they should be installed on? thank you.
Re: orientation of tubular UCAs [Re: Dadrules] #1190322
03/03/12 03:23 PM
03/03/12 03:23 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
When the UCA is installed, the ball joint mount hole axis should be close to vertical. Since the axis around which the arm rotates is canted down to the rear along the frame rail, the ball joint mount is canted the opposite direction to keep it relatively vertical...
(Sorry, don't have any decent pics.)
Re: orientation of tubular UCAs [Re: Dadrules] #1190323
03/03/12 05:53 PM
03/03/12 05:53 PM
Northern California
lilcuda Offline
lilcuda  Offline
Northern California
Here's a couple pictures of FF upper control arms on my 66 Barracuda. They also should be marked on top of the ball joint. Mine were.
'67 is an abbreviation of 1967
67' is an abbreviation of 67 feet
They are not interchangeable.
Re: orientation of tubular UCAs [Re: lilcuda] #1190324
03/03/12 05:54 PM
03/03/12 05:54 PM
Northern California
lilcuda Offline
lilcuda  Offline
Northern California
Passenger side...
Re: orientation of tubular UCAs [Re: lilcuda] #1190325
03/03/12 06:14 PM
03/03/12 06:14 PM
Keizer, Oregon
Dadrules Offline OP
Dadrules  Offline OP
Keizer, Oregon
Lee and Marq thank you both this is exactly what I needed to see
Re: orientation of tubular UCAs [Re: Dadrules] #1190326
03/04/12 02:40 AM
03/04/12 02:40 AM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
my hotchkis ones were marked as well..
Re: orientation of tubular UCAs [Re: MoparMarq] #1190327
03/04/12 03:39 AM
03/04/12 03:39 AM
Middleton, ID
curleysracecars Offline
Middleton, ID
This is how control arms SHOULD be built...however there are many that are not this way. The "cant" needs to be built into the arms so that at a static height, the ball joint is near the center of its movement in all axis'.
Kyle Curley
