roll bar rust #1189842
03/02/12 08:36 PM
03/02/12 08:36 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
so i got my 8 point bar out of storage. It is covered in surface rust. more than a scothc brite pad will remove. i have to use a wire wheel or flapper. very small pitting, but it is there. should i toss this and get a new one? will it still be safe?
its a chris alston steel kit
Re: roll bar rust [Re: 8urvette] #1189843
03/02/12 08:42 PM
03/02/12 08:42 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
i'd remove all the rust, use a rust inhibitor primer & paint it. why throw away good money?? seeya.
Re: roll bar rust [Re: rickraw] #1189844
03/02/12 08:43 PM
03/02/12 08:43 PM
tboomer Online work
tboomer  Online Work
What Rick says..
Re: roll bar rust [Re: tboomer] #1189845
03/02/12 08:48 PM
03/02/12 08:48 PM
tboomer Online work
tboomer  Online Work
Re: roll bar rust [Re: tboomer] #1189846
03/02/12 10:08 PM
03/02/12 10:08 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Rustoleum Hammertone brush on...Just used it on my 8 point roll bar. Two coats, looks great.
Re: roll bar rust [Re: Adobedude] #1189847
03/03/12 02:19 AM
03/03/12 02:19 AM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
i only saw the rattle can hammer stuff, where does one get brush on?
Re: roll bar rust [Re: 8urvette] #1189848
03/03/12 10:55 AM
03/03/12 10:55 AM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Lowes HomeDepot
The brush on silver is acutally Charcoal grey.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: roll bar rust [Re: Adobedude] #1189849
03/03/12 12:16 PM
03/03/12 12:16 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I would suggest Metal-Prep with a Scoth-Brite pad. The metal prep helps remove the rust while leaving an excellent base to paint on. Just a little messy to rinse it off. I use wet paper towel to rinse, then dry . Start at the top and work your way down in small areas. If it drys to soon just reapply. I'm sure my buddy that painted my cage would like the brush-on Hammer-Tone idea. He say's I have to paint my next cage myself.
Doug
