Good place to buy 426 Hemi block and heads #1189796
03/02/12 06:55 PM
03/02/12 06:55 PM
Wichita,KS
Blakcharger440 Offline OP
Wichita,KS
I am wanting to build a 500ci Hemi or larger for my 68 Charger project. It will be a street/strip type of build.
Where is a good place to buy the 426 aluminum Hemi heads and iron block at? I am wanting the block to have the RB type mounts.
What should I look for in purchasing a new iron 426 block and aluminum heads?
Should I buy the block in rough or finished bore? What about the lifter bores finish?
Re: Good place to buy 426 Hemi block and heads [Re: Blakcharger440] #1189797
03/02/12 07:01 PM
03/02/12 07:01 PM
First off, if you dont care about O.E appearance, I would start by looking at the world products block mopar sells. If you do car about appearance, look for a good older mopar performance block pre world casting. As far as aluminum heads, I would look for a set from mopar cast by edelbrock, not the earlier mopar castings. Ebay is your friend.
Re: Good place to buy 426 Hemi block and heads [Re: ] #1189798
03/02/12 07:08 PM
03/02/12 07:08 PM
Wichita,KS
Wichita,KS
I do not care about stock appearance. I didnt find much on ebay...I will check again.
Re: Good place to buy 426 Hemi block and heads [Re: Blakcharger440] #1189799
03/02/12 07:21 PM
03/02/12 07:21 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Blak,
check your PMS.
RIP Monte Smith
Re: Good place to buy 426 Hemi block and heads [Re: CompWedgeEngines] #1189800
03/02/12 07:36 PM
03/02/12 07:36 PM
Wichita,KS
Wichita,KS
Blak,
check your PMS.
I didnt receive a PM.
Re: Good place to buy 426 Hemi block and heads [Re: Blakcharger440] #1189801
03/02/12 08:18 PM
03/02/12 08:18 PM
AndyF Offline
AndyF  Offline
I know of a complete 528 crate Hemi that is for sale if you're interested. Shoot me a PM if you want the seller's contact info.
