Best way to clean nuts and bolts???? #1189443
03/02/12 12:10 AM
03/02/12 12:10 AM
woodcrest, CA
magnum440d100 Offline OP
woodcrest, CA
Cleaning the bolts on the 360 by soaking them in a glass jar of simple green and dawn dish soap. Then hitting them with a rag. I'm thinking there's a better way. I've heard of people tumbling nuts/bolts. What does that involve?? Where would I get a tumbler??? What media??? I'm planning on putting it back together after I chase the threads and clean the bolts. I want my torque readings accurate and I DON'T want any bolts working loose after a few miles. Any and all suggestions are welcome. Thank you
Re: Best way to clean nuts and bolts???? [Re: magnum440d100] #1189444
03/02/12 12:12 AM
03/02/12 12:12 AM
Texas
Daty Rogers Offline
World's Greatest Husband. I love you Robyn
Daty Rogers  Offline
Texas
I've seen tumblers at Hobby Lobby, some hobby store may have them, call around.
-Daty
Re: Best way to clean nuts and bolts???? [Re: magnum440d100] #1189445
03/02/12 12:19 AM
03/02/12 12:19 AM
IMGTX Offline
IMGTX  Offline
I use a wire wheel on a bench grinder and a set of leather gloves.
Fast, efficient and works great.
Do not forget to chase the threads in the block with a tap but DO NOT CHASE THE ROD BOLT THREADS OR NUTS!
Re: Best way to clean nuts and bolts???? [Re: IMGTX] #1189446
03/02/12 12:24 AM
03/02/12 12:24 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
..... with a tap but DO NOT CHASE THE ROD BOLT THREADS OR NUTS!
Hmmmm..... I never have done that but now that you mention it, it makes perfect sense!
Re: Best way to clean nuts and bolts???? [Re: IMGTX] #1189447
03/02/12 12:28 AM
03/02/12 12:28 AM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
I use an old solvent can, load it up with the hardware and pour in some laquer thinner or whatever. Shake it good for a few minutes and then dump everything out. Wash and rinse everything off with some dawn or simple green to get the solvent smell and as a final rinse. Cuts the grease,oil,rtv ect without stripping off any coating so they dont flash rust.
Re: Best way to clean nuts and bolts???? [Re: 135sohc] #1189448
03/02/12 12:44 AM
03/02/12 12:44 AM
woodcrest, CA
woodcrest, CA
that was going to be my next question. If I were to wire wheel everything down would it rust?? We are talking valve cover and oil pan bolts right now, but water pump bolts soon. Intake bolts are going to be new as are the head studs and exhaust bolts.
Thanks daty for the hobby shop tip. After I read that I remembered harbor freight. Gonna check them out in the AM. FOR NOW though I gotta get off the Internet and get my hands dirty lol. I have an old motor from who knows what I can put a wire wheel on it. Out to the shop lol
Re: Best way to clean nuts and bolts???? [Re: magnum440d100] #1189449
03/02/12 12:54 AM
03/02/12 12:54 AM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
Those harbor freight tumblers are a joke imo. I have one and for all the noise and electricity it consumes. my shaker can method works just as well and costs me nothing besides some solvent every few months.
Re: Best way to clean nuts and bolts???? [Re: 135sohc] #1189450
03/02/12 01:19 AM
03/02/12 01:19 AM
I'd suggest not useing w wire wheel (too aggressive) and if using taps/dies using a "thread chasing" set as it removes less metal than a thread cutting regular type & just cleans the threads. Shaking them up in a can of solvent sounds good then hand wire brush the threads. No exp w tumblers but I hear they work well
Re: Best way to clean nuts and bolts???? [Re: RapidRobert] #1189451
03/02/12 01:23 AM
03/02/12 01:23 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Carb cleaner will probably clean the best and the fastest. I usually use my hot tank, but the fasteners still need to be bead blasted after.
Re: Best way to clean nuts and bolts???? [Re: Jim_Lusk] #1189452
03/02/12 01:32 AM
03/02/12 01:32 AM
woodcrest, CA
woodcrest, CA
Update sort of. Tried the wire wheel and it cleans it quick. But I'm going to stick to the soak and scrub method. Then all I have to do is over the little bit of paint that's still there. I found a few tumblers on Craigslist I will check out. Experiment with used then get the good stuff.
I'd post pics but I can't attach anymore haha
Re: Best way to clean nuts and bolts???? [Re: magnum440d100] #1189453
03/02/12 01:52 AM
03/02/12 01:52 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
All this talk of wire wheels,paper towels and cleaners leave me ,been down that road many years ago . A quality ultrasonic (heated type) makes this task a non task,15 minutes gets even the nastiest bolts,brackets,or other small items clean as the day it was made. Yes, it costs a little up front but in the long run,if you do much work it really frees you up for more important tasks.http://www.lrultrasonics.com/
Re: Best way to clean nuts and bolts???? [Re: goldmember] #1189454
03/02/12 02:56 AM
03/02/12 02:56 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
There is nothing funny about cleaning parts with a wire wheel. Cheap and effective.
One problem though..... The wire strands from the wheel. They go everywhere! I've had them fly at my face, stick in my clothes, even my legs. One time at work, I kept getting an itch. After a few scratch sessions, I got pissed and pulled down my pants. There was a wire stuck in the bottom front of my underwear. Not good.
Re: Best way to clean nuts and bolts???? [Re: Kern Dog] #1189455
03/02/12 03:39 AM
03/02/12 03:39 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
I'm just giving a heads up to those that may want a better method. Keep using a wire brush if you like it. Yep those loose wires sure are fun. I still use a wire brush to refinish some Rolex watch bands and create texture on gold,silver jewelry and always find it entertaining.
Re: Best way to clean nuts and bolts???? [Re: Kern Dog] #1189456
03/02/12 07:35 AM
03/02/12 07:35 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Franken you are lucky that it stuck in your undies.I was wire wheeling at work once and it went straight into something you dont want a wire in.Man it didnt feel bad going in but it sure felt bad coming out.After that I wore a leather apron I made.Rocky
Chrysler Firepower
Re: Best way to clean nuts and bolts???? [Re: 135sohc] #1189457
03/02/12 09:47 AM
03/02/12 09:47 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I use a vibrator from Eastwood with water and the green piramids. Works good and is better than wire wheeling. imo'
HotRod magazine did a story on them this month. Although there picture are not impressive to me.
Re: Best way to clean nuts and bolts???? [Re: magnum440d100] #1189458
03/02/12 09:54 AM
03/02/12 09:54 AM
East Brunswick, NJ
finadk Offline
finadk  Offline
East Brunswick, NJ
I have used all of the methods mentioned and generally a combination of al thr above is needed. The ultrasonic cleaner is by far the best bang for the buck and the least labor intensive. If I had a pile of bolts off a grimy 40 year old block I'd soak them in your Solvent of choice (simple green and purple power are my favorites) to get the heavy stuff off first so you dont trash the solvent in the ultrasonic cleaner.
Follow up with 15 -20 minutes in the ultrasonic. I have a good general ultrasonic solvent to be the best in there. I tried dedicated ultrasonic rust removers but they did not work significantly better. If there is any rust left then you hit it with the wire wheel.
Good luck
Scott 1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed) 2002 Dodge Ram 1500 Quad Cab 1976 Corvette
Re: Best way to clean nuts and bolts???? [Re: finadk] #1189459
03/02/12 03:58 PM
03/02/12 03:58 PM
woodcrest, CA
woodcrest, CA
Good luck
The ultrasonic cleaner sounds nice. I followed the link posted but couldn't find a price.
Would I be fine with a harbor freight vibrator if I soaked the bolts in solvent first, cleaned with a wire brush (not wheel)??
Not looking for show quality, just a clean bolt.
Re: Best way to clean nuts and bolts???? [Re: magnum440d100] #1189460
03/02/12 04:35 PM
03/02/12 04:35 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
for rust EVAPO-RUST works well
Re: Best way to clean nuts and bolts???? [Re: mopars4ever] #1189461
03/02/12 08:21 PM
03/02/12 08:21 PM
East Brunswick, NJ
finadk Offline
finadk  Offline
East Brunswick, NJ
I got mine on eBay from seller e-fortune
Lookup item # 140333938761. I am very happy with my choice. It's small but I do the [Edited by Moparts - Family Friendly Site - Keep it clean] stuff in a 5 gallon pail using electralisis.
I gave away my harbor freight parts washer after getting these.
Re: Best way to clean nuts and bolts???? [Re: finadk] #1189462
03/02/12 09:16 PM
03/02/12 09:16 PM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
oven cleaner, shake them up and rinse with water, done
