Mopar techs need some help, 09 Sebring brake lights
#1189278
03/01/12 07:33 PM
03/01/12 07:33 PM
Posts: 5,796 minnarusta
TX9H6E4CUDA
minnarusta
My buddy has a 2009 Sebring 4 door and the car has no brake lights. It has taillights but no brake lights. The signals work great. Any suggestion
For the absolute best powder coating go to J.I.T powder coating, contact infomation is in my personal profile..
Re: Mopar techs need some help, 09 Sebring brake lights
[Re: TX9H6E4CUDA]
#1189279
03/01/12 08:07 PM
03/01/12 08:07 PM
Posts: 92 Michigan
Kudakid
Brake Switch. Its either bad or not adjusted properly.
2010 Challenger R/T
2001 Jeep Cherokee
1970 AAR Cuda
1970 T/A
[Re: Kudakid]
#1189280
03/02/12 10:11 AM
03/02/12 10:11 AM
Posts: 1,646 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
Check fuses first. Probably the brake switch, looks like it is under the hood. See pic .
Directions to remove Brake Switch: Depress and hold the brake pedal. Remove the stop lamp switch (2) from it's bracket on the brake pedal assembly (6). To do so, rotate the stop lamp switch in a counterclockwise direction approximately 30 degrees from its proper mounting position. Pull the switch rearward and remove it from its mounting bracket. Disconnect the wiring harness connector (1) from the switch.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
