daytona trunk photo??????? #1188961
03/01/12 04:38 AM
03/01/12 04:38 AM
phx
metalgod Offline OP
metalgod  Offline OP
phx
i need a detailed photo of the sissor jack placement and hold down clamp as well as the placement of the sissor jack handle can anyone help?????
Re: daytona trunk photo??????? [Re: metalgod] #1188962
03/01/12 05:54 AM
03/01/12 05:54 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
.....recalling from memory Doug, stud for sissor jack hold down, approx 20" measured from taillight panel to front of car, side measurement 13 1/2" from edge of trunk extension where it folds down into qtr, towards the center of the trunk, studs are usually just nut/bolt, some are welded from underneath
Mike
Re: daytona trunk photo??????? [Re: DAYCLONA] #1188963
03/02/12 01:56 AM
03/02/12 01:56 AM
phx
metalgod Offline OP
metalgod  Offline OP
phx
thank you so much you are the man, i assembled the nose as per your instructions wasnt so bad after all thanks to you Mike thanks! hey do you know if the reporoduction rear glass is still available for these cars?
Re: daytona trunk photo??????? [Re: metalgod] #1188964
03/02/12 11:42 AM
03/02/12 11:42 AM
central,pa
P
ply64post Offline
ply64post  Offline
P
central,pa
Not picking but shouldn't those wing braces
be black or is it a personal choice ?
Re: daytona trunk photo??????? [Re: metalgod] #1188965
03/02/12 11:48 AM
03/02/12 11:48 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Good to see you getting back to that Daytona Doug ...as far as the glass, word is that AMD is making back glass and SS trim for both the Tona' and the Bird,.....suppose to be tempered, not lanimated like the last repro's from OEM Glass Inc. (discontinued),...supposely a few months....we'll see?
Mike
Re: daytona trunk photo??????? [Re: DAYCLONA] #1188966
03/02/12 12:42 PM
03/02/12 12:42 PM
phx
metalgod Offline OP
metalgod  Offline OP
phx
probly should be black i just thought they looked good red
