Re: neon motor ,best way to remove it?
[Re: 72demon416]
#1188638
03/01/12 09:09 PM
03/01/12 09:09 PM
Posts: 394 md
wicked
md
That's the way I have done it in the past. I think it was a Mopar Action article that prompted me to do it this way but it was quite easy actually.
I have done one out the bottom, much easier to separate and realign that way when you can get to everything.
[Re: IMGTX]
#1188641
03/02/12 12:56 AM
03/02/12 12:56 AM
Posts: 12,036 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I have always swapped them from the top. Take the tranny mounts lose so it can move to the driver's side more and tip the engine up at a sharp angle. The engine just needs enough room to get the tone ring out of the tranny.
Master, again and still
[Re: 6PacCuda]
#1188643
03/02/12 05:40 PM
03/02/12 05:40 PM
Posts: 21,406 It's a dry heat
gtx6970
It's a dry heat
Done several out the top. I always remove the crank pulley when taking them out the top. It stays on when you drop it out the bottom.
done several of both the sohc and the dohc ,,all from the top
