Re: Jegs windage tray/gasket with stock oil pan
[Re: Dukes69]
#1188279
02/29/12 03:28 PM
02/29/12 03:28 PM
Posts: 1,606 westerly, ri. usa
440lebaron
westerly, ri. usa
do you have a part# i didnt know jegs had there own tray? milodon-moroso??
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: Dukes69]
#1188282
03/01/12 04:49 PM
03/01/12 04:49 PM
Posts: 3,821 New State
kidmopar
New State
I was curious if anyone has used the Jegs windage tray/gasket with a stock oil pan? I called and asked, of course they said it does, but I was hoping for some real world experience. It's going on a 70 hemi with a stock pan.
Thanks -Chris
[Re: 383man]
#1188284
03/01/12 07:28 PM
03/01/12 07:28 PM
Posts: 192 Temecula, CA
Dukes69
Temecula, CA
Is that the one that is the windage tray with the gaskets made on both sides of it ? If it is I have that here as my buddy dropped it off for me to use on his eng when I replace the rear main seal. Ron
Yes that's the one. I can see that it would work great if you had a flat pan rail like on an aluminum pan, not so sure about the stocker.
[Re: Dukes69]
#1188288
03/01/12 10:08 PM
03/01/12 10:08 PM
Posts: 1,532 crisfield, maryland 21817
82ramIndy493
Nevermind, I answered my own question. Put grease on the oil pan and installed it to see where it left marks. Practically the whole side of the oil pan is missed by the gasket, except around the bolt holes. I'll post pics to show what I'm talking about.
Great idea, garbage execution. 0 for 2, junk mancini rear main seal and junk jeg's oil pan gasket.
One day maybe some one will start making stuff that actually works.
Thats because its a Mopar part. If it was a Chevy or Ford part it would have been made to perfection.
[Re: Dukes69]
#1188289
03/02/12 08:22 AM
03/02/12 08:22 AM
Posts: 1,839 Sault Ste. Marie, Ontario, Can...
moparmike1
Hi, Here's another thread about this windage tray. Jegs Windage Tray I just finished putting one on my 400 with a factory 402 pan. The pan rail was pretty straight but with the thickness of this composite tray, I'm sure some minor dimpling would still be resolved. I have about an hour's worth of run time with the car on jack stands and probably another hour this weekend while I finish some other work. So far, no leaks and I've checked the pan rail area pretty closely. I'm very satisfied with this, especially considering the price. If someone wants, I can post a picture of the pan rail area to show the thickness of this part once it's installed. Mike.
[Re: Dukes69]
#1188292
03/02/12 06:30 PM
03/02/12 06:30 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Dukes69 that's exactly what I was refering to in the beads not sealing the pan in your first pic. I assume the Mancini seal retainer also uses the o-ring cord for the side seals, very problematic IMHO. Please click the link for some rear main seal help. The stock retainers are actually not that bad to work with if they are not beat up too bad. Stud clearacne is an issue and should always be checked. https://board.moparts.org/ubbthreads/show...t=1#Post5800228
[Re: Jeremiah]
#1188294
03/04/12 08:30 PM
03/04/12 08:30 PM
moparmike1
Hi,
Here are a few pictures to show the gasket with my oil pan.
Chris, I'm not sure what pan you have but you can see the gasket matches the rail on mine really well and it's like this all the way around. When you compare how close my pan is to the back of the block and then look at yours, it's definitely shaped different.
So far, no leaks. I would recommend the gasket.
I'll post a few more pictures.
Mike.
