Dumb question - carb spacer gaskets #1187737
02/28/12 09:30 PM
02/28/12 09:30 PM
Eugene, Oregon
Secret Chimp Offline OP
Eugene, Oregon
I'm using Edelbrock's thin little zinc adapter plate (like an 3/16 of an inch or something) to mate my AVS up with my spread-bore Performer manifold. It doesn't seem to be sealing too well - the idle hangs for a half second when I rev the engine.
The adapter plate included a square bore gasket only - I have that gasket, the plate, another thin gasket and my carb. My carb rebuild kit also came with a big thick rubbery gasket about 1/4 inch thick that I haven't tried out.
Am I supposed to use this plate with a spread-bore gasket between the plate and the manifold? Is it supposed to go metal-to-metal? Or should I just forget all of this junk and use the big thick gasket?
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: Dumb question - carb spacer gaskets [Re: Secret Chimp] #1187738
02/28/12 09:45 PM
02/28/12 09:45 PM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
Use the thick gasket!
Re: Dumb question - carb spacer gaskets [Re: Secret Chimp] #1187739
02/28/12 11:08 PM
02/28/12 11:08 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
You need a thin square bore gasket between the spacer and the intake , ore use some type of hardening sealer that is not affected by the crap we get for fuel.
