Re: V10 in a 1947 dodge truck
[Re: flyman]
#1187666
02/28/12 08:28 PM
02/28/12 08:28 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
no, no, dunno, no and maybe if you want to partially engineer your own (google megasquirt)
[Re: Dabee]
#1187668
02/28/12 09:24 PM
02/28/12 09:24 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
904 don't bolt up. It would need serious mods to hold the power if you found a way to adapt it. To run a carb you would need a custom sheet meatl one made. For ignition the only carbed one I ever saw had (I think)two 5 cylinder audi distributers modified to fire the ten plugs, driven off the crank with some sort of fancy custom drive set up.
