Carter AVS and an LD4B #1187642
02/28/12 05:55 PM
02/28/12 05:55 PM
White Hall, Maryland
MD72 Offline OP
MD72  Offline OP
I have a follow up question about an LD4B intake. After going through some of my old stuff, I found an old carburetor. It's a Carter AVS #4639SA. From what I found out about it, it is for a '69 340 with Auto. Trans. and A/C.
Am I good to go with my 318 .30 over and a mild cam?
Re: Carter AVS and an LD4B [Re: MD72] #1187643
02/28/12 06:30 PM
02/28/12 06:30 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Yes
Re: Carter AVS and an LD4B [Re: JohnRR] #1187644
02/28/12 06:56 PM
02/28/12 06:56 PM
Eugene, Oregon
Secret Chimp Offline
Eugene, Oregon
My AVS is intended for a lo-po 440. If mine works on my 318, yours will.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: Carter AVS and an LD4B [Re: Secret Chimp] #1187645
02/28/12 07:41 PM
02/28/12 07:41 PM
MD72 Offline OP
MD72  Offline OP
Thanks Guys!!! Winner! Winner! Chicken Dinner!!!
Re: Carter AVS and an LD4B [Re: MD72] #1187646
03/01/12 01:40 PM
03/01/12 01:40 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
Only the HiPo 440 AVS's had the larger primary throttle bores. I've seen a lot of the 4166S A-120 carbs for sale at swap meets. It must be the most common AVS out there. It's basically the same as a 340 or 383, but different jets and rods.
Floyd Lippencott IV
