6 qt Mopar Oil Pan ????? #1187636
02/28/12 05:46 PM
02/28/12 05:46 PM
Retired now in Tennessee
Chi_Town_Runner Offline OP
Bare with my thought process on this and tell me where I'm going wrong.
I have a built 383/438 ci engine for my ’68 RR. I had purchased the Mopar 6qt oil pan. Part # P5007807AB. In the Mopar Performance Catalog the description is as follows:
“Oil Pan, Six-quart, Center Sump, Stock Style, Must Use Oil Pickup P5007848, Stamped”
As I understand the catalog description, the pan holds 6 quarts and an additional quart for the filter.
Also, in my anal thinking, since I am using my stock dip stick the additional 2 quarts of oil, in what I presume to be a larger capacity pan based upon the description, the fill line on the dipstick should be relatively close the same level as my original 4 qt pan, meaning the surface of the oil level should be close to the same. No????
Well noooooo!!! When I have added 5 quarts to the pan the dipstick shows slightly overfull, let alone where the level is with 6 quarts. After I had added a total of 7 quarts, 6 in the pan 1 in the filter, I fired up the engine and while running checked the oil to see if it was frothy indicating my crank was slapping the oil. It was not. I have now marked my dipstick to where the oil level is and am using that as my full line.
Your thoughts?
Frank
Remember - 2 wrongs don't make a right - but 3 rights make a left!
Re: 6 qt Mopar Oil Pan ????? [Re: Chi_Town_Runner] #1187637
02/28/12 05:52 PM
02/28/12 05:52 PM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
When i look up P5007807AB i see 5QT pan not 6
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph
2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: 6 qt Mopar Oil Pan ????? [Re: Chi_Town_Runner] #1187638
02/28/12 05:54 PM
02/28/12 05:54 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i use that pan on my 69 r/t. it is 6qts with a filter.
Re: 6 qt Mopar Oil Pan ????? [Re: Savoy1964] #1187639
02/28/12 07:27 PM
02/28/12 07:27 PM
Savoy1964
Jim,
Here's a link. Not the exact catalog I got mine from but it's still listed as a 6 qt.
Maybe misprint .... ???
Mopar Catalog
lewtot184,
6 in the pan and 1 in the filter ???
Frank
EDIT:
DUH !!
After a little more research, Here is additional info:
From one of the catalogs:
Listed quart capacity is with filter installed
That answers a few questions. Apologies to Savoy 1964. You were right.Why did I doubt you ????
Thanks again to all.
Frank
Re: 6 qt Mopar Oil Pan ????? [Re: Chi_Town_Runner] #1187640
02/28/12 08:30 PM
02/28/12 08:30 PM
If you want the six quart stock oil pan like the 1970-71 Street Hemi /440-6 pak oil pan buy it from moparts or Hughes or Mancini and use the stock 440-6 pak 3/8 pick up I use them on all my BB now, haven't done a 1965 or earleir BB in a lot of yesr, maybe I'll do one later this year I wonder if the pan you bought is the Repo 1966 to 1969 Street Hemi oil pan? I use to use them on my 1963 M.W. stocker
Re: 6 qt Mopar Oil Pan ????? [Re: Cab_Burge] #1187641
02/28/12 11:03 PM
02/28/12 11:03 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
that pan is yet to be available in repop.
The 6qt pan is 5 plus the filter ... I would go by the old distck , full is full , a little over won't hurt much .
Re: 6 qt Mopar Oil Pan ????? [Re: JohnRR] #2359577
08/25/17 12:11 PM
08/25/17 12:11 PM
Virginia
V
varunner Offline
varunner  Offline
V
Virginia
I've been looking for this pan. Mopar dealer says dis-continued. Does anyone know if it has been re-popped yet ?
Re: 6 qt Mopar Oil Pan ????? [Re: Chi_Town_Runner] #2359617
08/25/17 01:17 PM
08/25/17 01:17 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Don't be the exception.
Re: 6 qt Mopar Oil Pan ????? [Re: Chi_Town_Runner] #2359638
08/25/17 01:58 PM
08/25/17 01:58 PM
Virginia
V
varunner Offline
varunner  Offline
V
Virginia
No 971 repo there.
Re: 6 qt Mopar Oil Pan ????? [Re: varunner] #2359648
08/25/17 02:10 PM
08/25/17 02:10 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Milodon makes a repo Hemi pan.
Re: 6 qt Mopar Oil Pan ????? [Re: Chi_Town_Runner] #2359653
08/25/17 02:24 PM
08/25/17 02:24 PM
Virginia
V
varunner Offline
varunner  Offline
V
Virginia
the 971 isn't the same as the hemi pan. lots of repo hemi pans out there. The 971 from what I understand holds 5 qts, look similar to the 402 pan, not as deep as the hemi pan which holds another qt. seems to be some confusion in descriptions on capacity.
Re: 6 qt Mopar Oil Pan ????? [Re: varunner] #2359695
08/25/17 03:28 PM
08/25/17 03:28 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Nothing special about the 971 pan. Pioneer makes one that doesn't have "971" stamped on it though.
http://www.rockauto.com/en/catalog/chrysler,1978,cordoba,6.6l+400cid+v8,1062717,engine,oil+pan,5562
Re: 6 qt Mopar Oil Pan ????? [Re: Chi_Town_Runner] #2360747
08/27/17 07:52 PM
08/27/17 07:52 PM
Virginia
V
varunner Offline
varunner  Offline
V
Virginia
Re: 6 qt Mopar Oil Pan ????? [Re: varunner] #2360793
08/27/17 08:54 PM
08/27/17 08:54 PM
IN
ahy Offline
ahy  Offline
IN
I always ran my "6 quart" Hemi pan with 5-5 1/2 quarts in the pan for the reason you mentioned. I did not want higher oil level. I think the 6 quart rating is a bit of a stretch.
My suggestion, run it with similar oil level as your previous pan and have fun.
Re: 6 qt Mopar Oil Pan ????? [Re: JohnRR] #2360796
08/27/17 09:00 PM
08/27/17 09:00 PM
Originally Posted By JohnRR
I wonder if the pan you bought is the Repo 1966 to 1969 Street Hemi oil pan? I use to use them on my 1963 M.W. stocker <img src="/ubbthreads/images/graemlins/thumbs.gif" alt="" />
Either Hughes or Mancini sells both the 1966/1969 and the 1970/71 repop Hemi oil pans up scope
The early street Hemi pan was 5 quart plus one for the oil filter, the 1970/71 Street Hemi and 440 6 pack oil pan is six quarts in the pan and one for the oil filter up scope
That one, 1970/71, is way better for the 1966 to 1971 B and E body cars with BB and Hemi motors in them up twocents
Re: 6 qt Mopar Oil Pan ????? [Re: Chi_Town_Runner] #2361115
08/28/17 12:56 PM
08/28/17 12:56 PM
Virginia
V
varunner Offline
varunner  Offline
V
Virginia
This is somewhat off-topic, but irregardless of what pan is on an engine, is it true that the oil level relative to the rotating assembly is always the same ? I would think so.
Re: 6 qt Mopar Oil Pan ????? [Re: varunner] #2361189
08/28/17 03:46 PM
08/28/17 03:46 PM
dogdays Offline
dogdays  Offline
That's a generalization that cannot be made. There are two factors at work here. First it is generally desirable to have the oil surface as far from the rotating parts as possible. For example there are dyno pans that are enormously deep. Second the underside of the oil pan can't hang too low or it will be damaged and maybe take the engine along with it. So with the engine a fixed distance from the ground, you can see that the designer has very little room to work with.
The trick is to get he oil level far enough from the crank without dragging the oil pan. So how to do this? One could widen the pan or lengthen the sump (dropped part of the pan). It'd be possible to have a high volume pan actually have the oil level below the full mark on the dipstick, because there would be more volume farther away from the crank.
I'd say it's a safe assumption that the oil in the pan should never be higher than the stock "full" mark on a stock dipstick.
R.
Re: 6 qt Mopar Oil Pan ????? [Re: varunner] #2361343
08/28/17 08:45 PM
08/28/17 08:45 PM
If I have a 12 quart drag race pan with a large kickout built in do you think it would have the same level as a stock OEM 402 or 917 4 quart will have work grin shruggy
I can tell you by having used both and running the larger oil pan with less than the stated capacity that the oil levels are not the same as my motors that have used the stock 402 and 917 pans that I added slosh baffles to shruggy
Re: 6 qt Mopar Oil Pan ????? [Re: Chi_Town_Runner] #2361364
08/28/17 09:20 PM
08/28/17 09:20 PM
crabman173
crabman173
Summit has the 6 qt quality pan $94 so why would you pay more? Summit branding of the Mopar perf pan
Re: 6 qt Mopar Oil Pan ????? [Re: Chi_Town_Runner] #2361405
08/28/17 10:38 PM
08/28/17 10:38 PM
Virginia
V
varunner Offline
varunner  Offline
V
Virginia
Sorry guys, I was wondering about oem pans. Say comparing a 4 qt. and a 6 qt. oem pans on a factory 440.
Here's a cheapo that would work.
http://www.cfrperformance.com/CHRYSLER_MOPAR_361_383_400_440_HEMI_426_OIL_PAN_p/hz-9496-pbk.htm
thanks for the insite.
