Re: 5.7 hemi vs 6.1 crank
[Re: xpsyclonex2002]
#1187103
02/27/12 12:57 PM
02/27/12 12:57 PM
Posts: 17,854 S.E. Michigan
ZIPPY
S.E. Michigan
5.7 cast 6.1 steel both neutral balance you can throw a 6.1 crank in a 5.7 without doing anything else, works great assuming the 5.7 is 2008 or older. I've done it several times now, works great.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#1187104
02/27/12 01:24 PM
02/27/12 01:24 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Are they not balanced different for different bob weights? Do the 5.7 and 6.1 have the same bob weight?
[Re: ZIPPY]
#1187105
02/27/12 04:16 PM
02/27/12 04:16 PM
Posts: 71 Memphis, MO
xpsyclonex2002
Memphis, MO
What has to be done if the block is a 2005?
#1187106
02/27/12 08:47 PM
02/27/12 08:47 PM
Posts: 1,130 Dayton, Ohio
wldtm
Dayton, Ohio
i think the crank tone wheel has a different trigger set up.
jm
Interested in having you car wired? Drag car, street car, EFI swap?
PM for details
[Re: wldtm]
#1187107
02/28/12 09:59 AM
02/28/12 09:59 AM
Posts: 2,826 NY usa
540challenger
NY usa
jm
I know the 6.4l crank tone ring is different but i thought all 5.7 and 6.1l were the same.
#1187110
03/02/12 12:45 AM
03/02/12 12:45 AM
HotRodDave
Kalispell Mt.
If it spun a bearing you need to take it apart for two reasons... first the rod is %99 chance it is toast, out of round or enlarged or both. Second is there is probably or should I say, there IS bearing material all over inside and it needs to be cleaned out.
