Pinion angle and pic: im dumb and confused sometimes #1186409
02/26/12 02:48 PM
02/26/12 02:48 PM
Iowa State fan
kilroy Offline OP
kilroy  Offline OP
Iowa State fan
Ok reading pinion angle, hear is the reading from my car.
Left is the front of the car - right is the driveshaft
Angle finder mounted on the input yoke.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
Re: Pinion angle and pic: im dumb and confused sometimes [Re: kilroy] #1186410
02/26/12 02:48 PM
02/26/12 02:48 PM
Iowa State fan
kilroy Offline OP
kilroy  Offline OP
Iowa State fan
And the rear end
mounted on yoke
rear is left and front of car is right
Re: Pinion angle and pic: im dumb and confused sometimes [Re: kilroy] #1186411
02/26/12 02:50 PM
02/26/12 02:50 PM
Iowa State fan
kilroy Offline OP
kilroy  Offline OP
Iowa State fan
Am I 3 + or 3 -.
Im using a caltrac style setup on HD springs. I already have 3* shims under the spring perches.
Re: Pinion angle and pic: im dumb and confused sometimes [Re: kilroy] #1186412
02/26/12 03:02 PM
02/26/12 03:02 PM
Iowa State fan
kilroy Offline OP
kilroy  Offline OP
Iowa State fan
Car on the ground at weight except empty fuel tank. (empty tank unfortunately is pretty normal).
Re: Pinion angle and pic: im dumb and confused sometimes [Re: kilroy] #1186413
02/26/12 03:19 PM
02/26/12 03:19 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Re: Pinion angle and pic: im dumb and confused sometimes [Re: astjp2] #1186414
02/26/12 03:28 PM
02/26/12 03:28 PM
Iowa State fan
kilroy Offline OP
kilroy  Offline OP
Iowa State fan
I think Im -3 according to this, as my trans is at 3 down and the rear is level.
http://www.buickperformanceclub.com/Pinion.htm
Re: Pinion angle and pic: im dumb and confused sometimes [Re: kilroy] #1186415
02/26/12 03:39 PM
02/26/12 03:39 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Compare the parallelism between the transmission and the pinion.
A zero degree pinion angle is when the transmission is parallel with the pinion.
A negative pinion angle is the number of degrees the pinion must rotate UPWARD to become parallel with the transmission.
A positive pinion angle is the number of degrees the pinion must rotate DOWNWARD to become parallel with the transmission.
For example, if the transmission slopes downward 3 degrees toward the rear, and the rearend is level, you have a true 3 degree negative pinion angle.
Re: Pinion angle and pic: im dumb and confused sometimes [Re: DoctorDiff] #1186416
02/26/12 09:04 PM
02/26/12 09:04 PM
nj pine beach
dart9ss Offline
dart9ss  Offline
nj pine beach
I understand you take the angle at the universal like you did and then off the drive shaft. subtract one from the other thats your angle. so you will have one neg. # and one postive #. then subtract.we run 7 degress with ss springs. not sure on caltracts. ask cal.my .02$
Re: Pinion angle and pic: im dumb and confused sometimes [Re: dart9ss] #1186417
02/26/12 11:28 PM
02/26/12 11:28 PM
Iowa State fan
kilroy Offline OP
kilroy  Offline OP
Iowa State fan
Thats just a little more complicated method and it allows you to get a drive shaft angle also.
I was just having a brain loss moment and wanted my figures double checked; after I didnt get any responses for a while I sat and figure it out.
Thanks Doc Diff for the response, I figure it a about the same time you responded.
