1990 318 #1186370
02/26/12 01:15 PM
02/26/12 01:15 PM
Downey, IA
Gt383 Offline OP
Gt383  Offline OP
Downey, IA
Can I turn up the timing on my tbi 1990 318 for a lil extra juice and mpg? I know on the magnums u set the rotor in place and the computer does the rest..Or will it be all wrong? Thanks moparts techs
If I hafta come in and getchya.......I'm gonna getchya!
Re: 1990 318 [Re: Gt383] #1186371
02/26/12 01:56 PM
02/26/12 01:56 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
You can advance the base timing on it to slightly improve mpg and performance, but it will throw the emissions off a bit.
Re: 1990 318 [Re: buildanother] #1186372
02/27/12 10:36 AM
02/27/12 10:36 AM
Downey, IA
Gt383 Offline OP
Gt383  Offline OP
Downey, IA
I live in eastern IA and it doesnt have to be sniff tested.. I have already removed the cat...airpump..and blocked the egr..Found that the egr was sticking...i removed it and plated it. That was a major improvement in power and mpg, jus was wondering if I coul d bump up the timing a little like the old carbed engines, I know you will mess up all sorts of issues in a magnum doin this.
Re: 1990 318 [Re: Gt383] #1186373
02/27/12 02:54 PM
02/27/12 02:54 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Yes you can set base timing on it as that would be a throttle body injection not multi-port. You have to unhook the coolant sensor to put it in open loop and then adjust the dist to set the base timing like on any eng. Ron
Re: 1990 318 [Re: 383man] #1186374
02/28/12 11:14 AM
02/28/12 11:14 AM
Downey, IA
Gt383 Offline OP
Gt383  Offline OP
Downey, IA
AH HA!! sweet, ive heard of this open loop ur reffering to, and that makes sense to me now. THANKS !!
