Brake Booster Rubber Boot #1186165
02/25/12 11:05 PM
02/25/12 11:05 PM
Hamburg, Pa.
72 RR DUDE Offline OP
Hamburg, Pa.
On a 72 B-body with power brakes is there any kind of foam or other material in the rubber boot on the power brake booster that is under the dash. Mine has little pieces of brown foam rubber coming out the holes. What can be used to replace the foam?
Re: Brake Booster Rubber Boot [Re: 72 RR DUDE] #1186166
02/26/12 04:31 PM
02/26/12 04:31 PM
Hamburg, Pa.
Hamburg, Pa.
Knowone ever have one of these apart?
Re: Brake Booster Rubber Boot [Re: 72 RR DUDE] #1186167
02/27/12 04:25 PM
02/27/12 04:25 PM
Utah
E
Eagleone1983 Offline
E
Utah
Mine was in the same boat. I actually ended up buying a new booster anyway. I was planning to just buy some black foam at a hobby/fabric store and cut it to the shape I needed which seemed to be a conical shape of some sort.
Re: Brake Booster Rubber Boot [Re: Eagleone1983] #1186168
02/27/12 06:50 PM
02/27/12 06:50 PM
Maryland
cudaboone Offline
cudaboone  Offline
Maryland
I have an OEM booster in original box if anyone is interested 300.00 with drum & disc brakes.
Re: Brake Booster Rubber Boot [Re: cudaboone] #1186169
02/27/12 07:24 PM
02/27/12 07:24 PM
Hamburg, Pa.
Hamburg, Pa.
I do believe that the foam is round like the boot and fits snug in the end of the boot where the holes are but how long is the foam 1" or is it longer?
Re: Brake Booster Rubber Boot [Re: 72 RR DUDE] #1186170
02/28/12 12:51 PM
02/28/12 12:51 PM
Utah
E
E
Utah
Just by looking at mine, it looks to be about as long as the boot is when extended
