Re: orange coolant in he 99 300M
[Re: azmopar]
#1186098
02/25/12 09:10 PM
02/25/12 09:10 PM
Posts: 27,728 places
79powerwagon
places
Does it say on a sticker under the hood?
These organic coolants come in two flavors. The "DexCool" was one kind, and then there is another.
My car uses G-05 and it's made by Zerex.
OAT vs HOAT, that's what I was trying to remember! According to this jug of Zerex (luckily it's in my house right now), your 99 should take conventional coolant, and in model year 2001 is when it went to HOAT... But verify that with your sticker.
[Re: 79powerwagon]
#1186099
02/25/12 09:22 PM
02/25/12 09:22 PM
There are actually more than two flavors. Don't use the universal unless you have an empty flushed system. My VW uses GL-12 and has warnings all over the manual and under the hood to only use that specification. I have witnessed the brown diahrea that results from mixing coolants in other vehicles.
[Re: ahy]
#1186101
02/26/12 08:54 AM
02/26/12 08:54 AM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
The Universal mixes with all coolants.We used it for years at the shop with no problems in tons of different cars.You cant mix the old standard Green with Dex cool or some others.Rocky
Chrysler Firepower
[Re: 71sat440]
#1186104
02/26/12 12:54 PM
02/26/12 12:54 PM
Posts: 6,022 Morningside
AdventurerSport
waaaay out there in left field
Morningside
I use Universal mix from NAPA, and have for many years, on everything I have. No issues. That said, along with all the vehicles I have in my signature, I've also used this on: 2005 300C AWD 2008 Ram Hemi IH 560 AC 190 NH 9070 Combine NH TG255 tractor NH 8970 tractor Versatile 846 AGCO DT225B tractor Farm stuff switched to DexCool or whatever the red stuff is called around 2001-2002, so my 1999 8970 still had green coolant but my newer stuff did not. With 3 people working on the farm, I had to decide whether to stock 1 style coolant that works with everything (universal), or try to keep green in green and red in red with my Dad randomly grabbing any bottle that says coolant and dumping it in!! So, since 2005 or so, I only buy the Universal and have used it in almost everything I own ever since. Only my Hemi Ram hasn't had it, but I haven't had to add any since I bought her in Nov 2011! JS
76 Dodge Adventurer Sport Power Wagon W100 318, 727, NP203 Fulltime 4x4 Russet Red 06 Jeep Commander Ltd 4x4, 5.7L Hemi, QuadraDrive II 06 Chrysler 300C AWD 5.7L Hemi 10 Mopar 10 Challenger R/T, #483/500, 5.7L HEMI 10 Jeep Grand Cherokee Ltd 4x4 5.7L HEMI 11 Dodge Ram 1500 LoneStar Quad Cab, 5.7L HEMI, Fulltime 4x4, Deep Cherry Red 16 Jeep Cherokee Limited 3.2L Pentastar V6, 9 Speed Torqueflite, 4x4, Black
[Re: 71sat440]
#1186105
02/26/12 01:55 PM
02/26/12 01:55 PM
If the prestone and other universals didn't mix with other antifreezes don't you think there would be mass law suits in the media by now from destroyed engines
Whenever I check someone elses coolant level and discover the fluid is a brown color with slime lining the reservoir, I know they have used a non original replacement. I fell into this trap myself when I changed the water pump on the wife's '05 T&C and used prestone universal to replace the lost fluid. Over the course of about six months the fluid changed to a brown color and became lumpy and slimy. I flushed the system and refilled from scratch with some overpriced coolant purchased from the dealer. I suppose this doesn't mean an incompatability issue has occured by mixing of fluids as long as they do their jobs. Maybe it's only aesthetics.
#1186106
02/26/12 04:13 PM
02/26/12 04:13 PM
Posts: 13,878 Willow Grove PA
71sat440
Willow Grove PA
Water Wetter admits to that.
I had a 95 mustang I put water wetter in and thought I blew a head gasket when I checked my coolant a month later. (chunky brown stuff floating in resevior.)
After searching the net I found a complaint sent in to water wetter and there response was something like "Do to a reaction with rust preventatives in certain antifreezes water wetter will appear to clump up when anti freeze is cold, do not worry it dissolves as it warms up and retains still retains its properties"
Our shop has used it for years (universal antifreeze)in every thing which is probably hundreds of cars per year and never had a complaint or issue.
