alternator swap #1185128
02/23/12 11:13 PM
02/23/12 11:13 PM
Ohio
RonaldV Offline OP
RonaldV  Offline OP
Ohio
Will a square back alt. off a 1986 360 dodge truck be a bolt in for early 70s electronic ignition car??? Im converting my points to electonic using all mopar parts. I have this alt. laying around.
Will it work??
Re: alternator swap [Re: RonaldV] #1185129
02/23/12 11:32 PM
02/23/12 11:32 PM
RapidRobert Online content
RapidRobert  Online Content
Will it work??
Like a charm. Get your pulley alignment dead on & you're good
Re: alternator swap [Re: RapidRobert] #1185130
02/24/12 08:19 AM
02/24/12 08:19 AM
Ohio
RonaldV Offline OP
RonaldV  Offline OP
Ohio
thanks,
My bet is the 86 alt. came off a optioned out 4x4 ramcharger with 4bbl and is a higher output alt. Ill do some research and find out.
Re: alternator swap [Re: RonaldV] #1185131
02/24/12 04:30 PM
02/24/12 04:30 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Mostly sure will need just to use longer belts, due the slightly bigger case on lates alts makes the back of alt to meet with block. That won't allow you to use the original lenght belts
