Why do tunnel rams use so much more CFM?
#1184581
02/23/12 02:05 AM
02/23/12 02:05 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Why is it that a motor that might normally perform at its optimum with say an 850 or 950 when using a single plane such as an M1 or Victor, is suddenly be able to swallow in upwards of 1500 cfm with a tunnel ram bolted on?
The only thing I can figure is that the plenum volume swallows a lot of that CFM???, but I've never had it explained to me. Anyone have solid reasoning for this?
Re: Why do tunnel rams use so much more CFM?
[Re: StealthWedge67]
#1184584
02/23/12 03:32 AM
02/23/12 03:32 AM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
Why is it that a motor that might normally perform at its optimum with say an 850 or 950 when using a single plane such as an M1 or Victor, suddenly be able to swallow in upwards of 1500 cfm with a tunnel ram bolted on?
It is how the air/fuel is used, Even with say 2 750s, doesn't mean the engine is useing all 1500 cfm, because in reality its not, If you do a search on TRs & how they work you'll understand it, Just thinking about it will confuse you, Always remember this, an engine will only take in what it wants, so if you have a true 850 cfm carb, the engine may only be useing 760 cfm at WOT, theres alot more to understand, i'd research.
[Re: d330]
#1184586
02/23/12 11:51 AM
02/23/12 11:51 AM
Posts: 3,505 DFW
mr_340
DFW
Think in terms of pressure drop across the carbs. 4bbl carbs are flowed at 1.5"Hg (20.4" H2O). Using the standard formulas, if you picked the right carb you would have 1.5"Hg pressure drop @ WOT. A bigger carb would give you less pressure drop, increased density of charge in the cylinder. More air+fuel=more HP. Same reason to use bigger cams is to get the charge density up at high RPM. ![](/ubbthreads/images/graemlins/Twocents.gif) I'm sure the SS Hemi's could use bigger carbs and would gain even more power if they could run two Dominators. I think there was an interview with Harry Holton about ten years ago and he said the carbs were a limitation. They are almost 200 HP higher now than when Timex made 900 HP.
Floyd Lippencott IV
#1184587
02/23/12 12:26 PM
02/23/12 12:26 PM
Posts: 10,021 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I'm no carb wiz but here is what I understand- all you need is proper fuel atomization for good power at the minimum rpm you run. A street car may need to go WOT at 2500 rpm. Lets say the biggest carb on our 440 v8 than can do that well is a 750. to atomize fuel properly, the carb may restrict the air coming in by about one third what it will at high rpm. The true air flow will be maybe 300 cfm, and the true vacuum will probably be only about .6 inchs of vacuum. But the carb needs enough air flow ( and restriction) to do its' job of pulling fuel out of the boosters and atomizing it. Go below a certain air speed, and no fuel comes out. Tunnel rams run at much higher rpm as a rule, and being race only (for the most part) will only need to function well from about 5,000 rpm up. So the TR set up could use two 750s, for 1500 cfm and get away with it, also reducing total vacuum and gaining power that way plus the tuned length of the manifold itself. You can also increase the size of the carbs some with boosters that work better at lower rpm and modify the fuel curve to fit the situation better. Vacuum secondary carbs get around this problem some, allowing use of 800 cfm carbs on small blocks of only 340 cubes. Fuel injection goes a step further, providing the energy to atomize the fuel with a pump. So the system will function with much more airflow. Total vacuum can be reduced to almost zero when you can run a "hat" that flows over 3,000 cfm. My Terminator deal with 2100 cfm struggled to pull .5 inch vacuum at max rpm on the dyno.
[Re: gregsdart]
#1184588
02/23/12 02:36 PM
02/23/12 02:36 PM
Posts: 12,418 Taxes & Virus's R-US, NY
Dragula
And carbs don't flow what they are stated to flow either.. Stock carbs, especially eddy carbs, flow a lot less than the stated cfm...So be careful when you start broadly comparing "CFM ratings" of carbs.
Just like a factory engine that has been blue printed, a carb also needs attention to detail and a good going thru. Don't even assume that SS carbs are out of the box with all the factory workmenship flaws that yours might have. I assure you, they are not in 90% of the cases. Attention to detail should not be limited to the heads on an engine. Heck I even port my header flanges to makes sure they flow as good as they can.
With that said, my efi Tunnel Ram flows 2100cfm on my 484 Hemi, and it is pretty awesome for throttle response.
[Re: CNC Waterjet guy]
#1184590
02/27/12 02:31 PM
02/27/12 02:31 PM
Posts: 2,578 sweden
1Fast340
sweden
one of the reasons for the big carbs is that your tunnelram works alitle like a I.R manifold each barrel feeds one cylinder and the plenum should realy only be there to smooth out the pulses that most american performance carbs dont like to be subjected to. fuel atomization is a much smaller problem when the fuelairmixture dont have to make any 90degree turns betwen the carb and the intakevalve. with the straight shoot from the carbbarrel down to the intakevalve you DONT want any restriction forcing the cylinder to draw air and fuel from more barrels than neccesary. with the right combo tunnelrams work great even on the street and will be increadibly quick repsonding to input from your right foot. ![](/ubbthreads/images/graemlins/thumbs.gif) forget about all the bull about "its a raceonly intake that only works from 12565215454rpms and up" just get the combination right and they are great
#1184591
02/27/12 03:04 PM
02/27/12 03:04 PM
Dragula
I'm guessing that you were refferring to "3-two barrells" on a tunnel-ram? You have my interest peaked! I would like to install an old Offenhauser tunnel-ram that I have made a 3x2 top for, but still havent descided how to go at it carburetor wise - do I get 3 NOS six pack carbs, or get 3 regular 2300's with metering plates and run a non-vacuume linkage? How did you do it? jetting recomendations? B.T.W. it will be on a Victor headded 500 c.i. low deck about 10:5/ 11:1 compression unit.
Use three center carbs all worked over by Quick fuel. Forget about doing the OEM vacuum thing....You will only end up where I am telling you to go after spending more money and getting frustrated.
#1184592
02/27/12 03:42 PM
02/27/12 03:42 PM
Posts: 43,315 Bend,OR USA
Cab_Burge
I can testify about BB Mopar motors with standard 440 heads and M.W. size heads, the more air you give them the faster they go ![](/ubbthreads/images/graemlins/shock.gif) It must be something in the designs ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) Not the genes, jeans, geans ![](/ubbthreads/images/graemlins/whistling.gif) all kidding aside a drag motor is not the same, even drag racing a stock motor, as the stock motor and the way there driven ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) I have had a bunch of other brand(Chevys and other GM motors) racers tell me that I'm crazy on the size carbs I use on my motors, street and strip motors. ![](/ubbthreads/images/graemlins/shruggy.gif) Theory is one thing, actual results in the real world are many times not the same ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) Test,test and test some more to learn ![](/ubbthreads/images/graemlins/thumbs.gif)
#1184594
02/28/12 01:54 PM
02/28/12 01:54 PM
Posts: 4,213 New York
polyspheric
New York
Let's call this thread "the blind men and the manifold".
Boffin Emeritus
[Re: polyspheric]
#1184595
02/28/12 03:09 PM
02/28/12 03:09 PM
Posts: 235 Tucson AZ.
RADAMX
Tucson AZ.
I am no expert either. As I undersatand it, the longer straight runner Packs the air behind the valve . Allowing more air and fuel to enter the cylinder when the valve opens .similar to forced induction on a small scale. if you can get the air moveing in one direction it does not just stop when the valve closes it packs at the valve . I have seen tunnel rams make better power at lower rpm than even a torker intake . it is all based on runner length and size verses rpm. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: polyspheric]
#1184596
02/28/12 04:11 PM
02/28/12 04:11 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
Interesting reading.
http://victorylibrary.com/mopar/intake-tech-c.htm
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
