Blue Smoke From Exhaust... #1184468
02/23/12 12:05 AM
02/23/12 12:05 AM
Middle River, MD
Mapandjlp Offline OP
Middle River, MD
To avoid confusion, I've started my own thread on this topic.
Build is 360 + .030
KB107 pistons
340 rods
596 heads
Comp XE268
Performer Intake
Eddy AVS carb
I built the motor. Rings were properly sized and staggered.
The motor has at least 3k since the rebuild and runs super! After cruising awhile, it'll smoke heavily upon hard acceleration. Once it's "blown out", it won't smoke for a bit. Then after some more cruising, it'll smoke again on hard acceleration...etc, etc...
It also seems to use a quart of oil every few hundred miles or so and the oil seems to stay pretty dark, even after an oil change.
I've replaced the intake gasket once with no change.
I bought the heads "already done" and to be honest, never even looked at the valve seals.
Thoughts? Valve Seals? Rings not seated?
Re: Blue Smoke From Exhaust... [Re: Mapandjlp] #1184469
02/23/12 12:13 AM
02/23/12 12:13 AM
Eugene, Oregon
Secret Chimp Offline
Eugene, Oregon
Build is 360 + .030
KB107 pistons
340 rods
596 heads
Comp XE268
Performer Intake
Eddy AVS carb
Valve seals. Cruising lets oil build up, hard acceleration sucks it past the bad seals enough to burn. They are super easy to change.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: Blue Smoke From Exhaust... [Re: Secret Chimp] #1184470
02/23/12 08:48 AM
02/23/12 08:48 AM
Canton, Ohio
Crazy68Dart Offline
Crazy68Dart  Offline
Canton, Ohio
What is your setup for a breather and PCV?
383, Hemi 4-Speed, AlterKtion, D60
Re: Blue Smoke From Exhaust... [Re: Crazy68Dart] #1184471
02/23/12 12:09 PM
02/23/12 12:09 PM
Middle River, MD
Middle River, MD
Valve covers are baffled. PCV on one side feeding to the base of the carb. Breather on the other side. I've tried replacing the PCV with a breather (effectively eliminating the possibility of oil being sucked into the base of the carb) with no change.
