Re: Blue Smoke From Exhaust...
[Re: Mapandjlp]
#1184469
02/23/12 12:13 AM
02/23/12 12:13 AM
Posts: 817 Eugene, Oregon
Secret Chimp
Eugene, Oregon
To avoid confusion, I've started my own thread on this topic.
Build is 360 + .030 KB107 pistons 340 rods 596 heads Comp XE268 Performer Intake Eddy AVS carb
I built the motor. Rings were properly sized and staggered.
The motor has at least 3k since the rebuild and runs super! After cruising awhile, it'll smoke heavily upon hard acceleration. Once it's "blown out", it won't smoke for a bit. Then after some more cruising, it'll smoke again on hard acceleration...etc, etc...
It also seems to use a quart of oil every few hundred miles or so and the oil seems to stay pretty dark, even after an oil change.
I've replaced the intake gasket once with no change.
I bought the heads "already done" and to be honest, never even looked at the valve seals.
Thoughts? Valve Seals? Rings not seated?
Valve seals. Cruising lets oil build up, hard acceleration sucks it past the bad seals enough to burn. They are super easy to change.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
[Re: Crazy68Dart]
#1184471
02/23/12 12:09 PM
02/23/12 12:09 PM
Posts: 509 Middle River, MD
Mapandjlp
Middle River, MD
What is your setup for a breather and PCV?
Valve covers are baffled. PCV on one side feeding to the base of the carb. Breather on the other side. I've tried replacing the PCV with a breather (effectively eliminating the possibility of oil being sucked into the base of the carb) with no change.
