SEM Color Coat question #1183477
02/21/12 01:36 PM
02/21/12 01:36 PM
SE Pa.
LimeliteAero Offline OP
SE Pa.
Has anyone ever sprayed this with a gun using their flattening agent?
I just used the aerosol and I think its a little too glossy so Im leaning towards going with the gun and some flattner.
Man it never ends! Im gonna have enough crap sitting on the shelf to do at least one more car!
Re: SEM Color Coat question [Re: LimeliteAero] #1183478
02/21/12 02:17 PM
02/21/12 02:17 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I've used both Dave, you do know there's several clears to coat over after dyeing a piece, low luster, satin gloss, and gloss, i usually recommend the clear coats, esp on light colors, or to affect shade/value changes for subtle color shift, just like the factory interior pieces were/are, esp black (SEM Landau black) when doing a whole dash, different sheen clears (low lustre & Satin) create a nice contrast of the same color to differentiate the dash fashia from the surrounding upper/lower pads, or metal frame structures, rather than having it look all the same color/sheen.....that's when it looks dyed to the observer
Mike
PS I answered your PM @ DC.com
Re: SEM Color Coat question [Re: DAYCLONA] #1183479
02/21/12 03:26 PM
02/21/12 03:26 PM
SE Pa.
SE Pa.
Hey Mike,
I got the PM! THANKS!!!!
Im painting the hard interior plastics on a 70 RR. I used the Landau Black and its got more gloss than the original unpainted parts. I also have a new set of the dash parts from B,E&A for the gauges, radio and above the glove box. the new parts are really flat and I didnt want to be too glossy next to them. I did hit one of the test pieces with the low luster clear and it knocked some of the gloss out of the Landau Black but still seems too glossy.
Just wondering if the flattner would help me out?
Re: SEM Color Coat question [Re: LimeliteAero] #1183480
02/21/12 03:53 PM
02/21/12 03:53 PM
Back in NJ....
E
EWJ Offline
EWJ  Offline
E
Back in NJ....
You might want to give SEM Trim Black a try- might be a little flatter.
Ed
EastCoast Land Yacht Assoc.
1967 Newport Conv: 440/4 speed
1969 GTX: 440/4 speed, TX9/TX9, A34, N96
1970 Super Bee: 383/4 speed, B5/B7
1970 Coronet RT: 440/4 speed, A34, N96
1970 Coronet RT: 440/auto, A36, N96
1970 Road Runner convertible: 383/4 speed TX9/D6XW
1970 GTX: 440+6/727, A32, N96
2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed
"The early bird may get the worm, but the 2nd mouse gets the cheese".
Re: SEM Color Coat question [Re: EWJ] #1183481
02/21/12 05:10 PM
02/21/12 05:10 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
The Landau Black had a little less gloss then my original Challenger panels.
Trim Black does have a little less gloss but I don't think it's designed for interior plastics and vynal parts.
Re: SEM Color Coat question [Re: burdar] #1183482
02/21/12 05:51 PM
02/21/12 05:51 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Trim Black is for exterior "black" plastic trim, should be fine for interior as well...if you like the low lustre gloss finish
Re: SEM Color Coat question [Re: DAYCLONA] #1183483
02/22/12 12:28 PM
02/22/12 12:28 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Although trim black is a good choice for interior metal trim pieces, for bucket seats, window and headliner trim.
logan426
Re: SEM Color Coat question [Re: MLR426] #1183484
02/22/12 12:43 PM
02/22/12 12:43 PM
SE Pa.
SE Pa.
when you say bucket seats, are you referring to the supports?
Mine seem to have been gloss Black.
Re: SEM Color Coat question [Re: LimeliteAero] #1183485
02/24/12 04:47 PM
02/24/12 04:47 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
hindge covers
logan426
Re: SEM Color Coat question [Re: MLR426] #1183486
02/25/12 10:16 AM
02/25/12 10:16 AM
SE Pa.
SE Pa.
Thanks everyone!
Ive pretty much decided to go with the Landau Black with no clear on the dash pads plastic,A-pillar trim,kick panels,defroster vents,seat backs, and hinge covers and anything I find that I havent mentioned.
