Re: SEM Color Coat question
[Re: LimeliteAero]
#1183478
02/21/12 02:17 PM
02/21/12 02:17 PM
Posts: 18,157 Mass
DAYCLONA
Mass
I've used both Dave, you do know there's several clears to coat over after dyeing a piece, low luster, satin gloss, and gloss, i usually recommend the clear coats, esp on light colors, or to affect shade/value changes for subtle color shift, just like the factory interior pieces were/are, esp black (SEM Landau black) when doing a whole dash, different sheen clears (low lustre & Satin) create a nice contrast of the same color to differentiate the dash fashia from the surrounding upper/lower pads, or metal frame structures, rather than having it look all the same color/sheen.....that's when it looks dyed to the observer
Mike
PS I answered your PM @ DC.com
[Re: LimeliteAero]
#1183480
02/21/12 03:53 PM
02/21/12 03:53 PM
Posts: 3,464 Back in NJ....
EWJ
Back in NJ....
You might want to give SEM Trim Black a try- might be a little flatter.
Ed EastCoast Land Yacht Assoc. 1967 Newport Conv: 440/4 speed 1969 GTX: 440/4 speed, TX9/TX9, A34, N96 1970 Super Bee: 383/4 speed, B5/B7 1970 Coronet RT: 440/4 speed, A34, N96 1970 Coronet RT: 440/auto, A36, N96 1970 Road Runner convertible: 383/4 speed TX9/D6XW 1970 GTX: 440+6/727, A32, N96 2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed "The early bird may get the worm, but the 2nd mouse gets the cheese".
[Re: burdar]
#1183482
02/21/12 05:51 PM
02/21/12 05:51 PM
Posts: 18,157 Mass
DAYCLONA
Mass
The Landau Black had a little less gloss then my original Challenger panels.
Trim Black does have a little less gloss but I don't think it's designed for interior plastics and vynal parts.
Trim Black is for exterior "black" plastic trim, should be fine for interior as well...if you like the low lustre gloss finish
[Re: DAYCLONA]
#1183483
02/22/12 12:28 PM
02/22/12 12:28 PM
Posts: 4,799 ILL
MLR426
ILL
Although trim black is a good choice for interior metal trim pieces, for bucket seats, window and headliner trim.
logan426
[Re: LimeliteAero]
#1183485
02/24/12 04:47 PM
02/24/12 04:47 PM
Posts: 4,799 ILL
MLR426
ILL
when you say bucket seats, are you referring to the supports?
Mine seem to have been gloss Black.
hindge covers
logan426
