Page 2 of 3 1 2 3
Re: well im now in the tunnel ram club- i have a question [Re: shoebox] #1183407
02/22/12 06:00 PM
02/22/12 06:00 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
biginch that sure is nice.
do the M1 or Weiand tunnel rams fit under a sixpack scoop ?on a RB block
don't look to sit too high
sorry for the hijack shoebox
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: well im now in the tunnel ram club- i have a question [Re: tex013] #1183408
02/22/12 06:39 PM
02/22/12 06:39 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
I have 2 660 center squirters on mine. Changed some things around on them also....Still messing with the jets.
Re: well im now in the tunnel ram club- i have a question [Re: 70HemiGTX] #1183409
02/22/12 06:47 PM
02/22/12 06:47 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Tex,
Yes it fits under the Unlimited fiberglass hood I have with a 6 pack scoop. Mine is a low deck with B1-BS heads.
Re: well im now in the tunnel ram club- i have a question [Re: Biginchmopar] #1183410
02/22/12 07:14 PM
02/22/12 07:14 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
thanks Biginch,
i have the UP22 sixpack hood with RB.
though i have a 2 spd wiper - may hit rear carb
just a thought anyway.maybe keep looking at the modman
Tex
New best MPH 130.32
Re: well im now in the tunnel ram club- i have a question [Re: MRMOPAR622] #1183411
02/22/12 07:14 PM
02/22/12 07:14 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
two 850s
1.39 9.85 - 137 mph
Re: well im now in the tunnel ram club- i have a question [Re: Ari440] #1183412
02/22/12 07:34 PM
02/22/12 07:34 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
ARI i like the regulator and line setup.. imight have to use your layout!
74 dart sport 440 www.Csucarbs.com
Re: well im now in the tunnel ram club- i have a question [Re: shoebox] #1183413
02/22/12 07:54 PM
02/22/12 07:54 PM
organ
maximum entropy Offline
organ
you know, those things don't look THAT tall...
Re: well im now in the tunnel ram club- i have a question [Re: maximum entropy] #1183414
02/22/12 07:59 PM
02/22/12 07:59 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
5 1/2 tall sixpack scoop on my old MAZ liftoff hood
the 4 inch tall scoop would not work
1.39 9.85 - 137 mph
Re: well im now in the tunnel ram club- i have a question [Re: Ari440] #1183415
02/22/12 08:03 PM
02/22/12 08:03 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
throttle bracket from ANDYF made to work with a lokar cable
1.39 9.85 - 137 mph
Re: well im now in the tunnel ram club- i have a question [Re: shoebox] #1183416
02/22/12 09:19 PM
02/22/12 09:19 PM
Central Missouri Fort Leonard...
mopar65 Online happy
mopar65  Online Happy
i just got my TR last night, its a weiand 5987 stage2. no cracks,mods,stripped holes etc. looks real good. when you look into the tops you can see where the upper meets the lower. there is a step there. like the lower openings need to be ported. is that a MUST DO? have you seen it worth 20 horse on the dyno? if i can leave it thats ok. stock stroke 440, 4800stall 6500rpm tell me anything you know of the history about the stage2.. any good?
shoe box here is how far the two parts of my intake was off.i just bolted mine together and used some sanding rolls and ported the intake until every thing matched. i ran out of time and sanding disc to port match the intake runners.will do that next time i have the intake off.thanks mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: well im now in the tunnel ram club- i have a question [Re: Ari440] #1183417
02/22/12 09:22 PM
02/22/12 09:22 PM
can you show a close up of how you made the bracket work? that's going to be my next question soon. i mean what kind of throttle bracket i will need to hook up my lokar throttle cable to my tunnel ram. thanks Mopar65
Re: well im now in the tunnel ram club- i have a question [Re: mopar65] #1183418
02/22/12 09:28 PM
02/22/12 09:28 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
1.39 9.85 - 137 mph
Re: well im now in the tunnel ram club- i have a question [Re: Ari440] #1183419
02/22/12 09:38 PM
02/22/12 09:38 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
1.39 9.85 - 137 mph
Re: well im now in the tunnel ram club- i have a question [Re: Ari440] #1183420
02/22/12 09:39 PM
02/22/12 09:39 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
look at the bracket that bolts througth the manifold
I used a cut off wheel and grinded the back bottem side so the trottle bracket would slide under
oblonged the throttle bracket to slide up or down to adjust heigth
found scrap metal 1 1/2 wide 3 inch long
the top part of ANDYF,S bracket I cut it up and used the kickdon section and bolted it together ,the length of the lokar cable deremined where to bolt it together
also with the cutoff wheel I cut a slit in the hole of the kickdown setion so I could slide the cable througth then taking it all apart
1.39 9.85 - 137 mph
Re: well im now in the tunnel ram club- i have a question [Re: Ari440] #1183421
02/22/12 09:45 PM
02/22/12 09:45 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
I actually just used a factory throttle cable bracket with a Lokar cable. Don't know if you can see it.
Re: well im now in the tunnel ram club- i have a question [Re: shoebox] #1183422
02/22/12 09:58 PM
02/22/12 09:58 PM
South Bend, Indiana
mistress Offline
mistress  Offline
South Bend, Indiana
I also am using a factory bracket that has been modified with lokar cable, also a belt drive fuel pump with return system and bypass regulator off fuel block i made. (I am using methanol)
Re: well im now in the tunnel ram club- i have a question [Re: mistress] #1183423
02/23/12 02:39 AM
02/23/12 02:39 AM
Pa
W
W7_Scamp Offline
W7_Scamp  Offline
W
Pa
Shoebox whats ur combo? I have that exact intake on my street car. I had 2 450 mechanical secondary carbs on it and ran 11.70 took them off put on 2 600 vac secondary carbs and ran 11.50's the 600's also had metering plates put in the back. .030 over 440 w factory heads cleaned up a bit and comp solid lift 570? lift cam 3500 converter and a whopping 323 gear. My 60ft's were a tad better w the 450's but the 600's picked up every where else. best 60 was like 1.79 and fastest mph was 119.
I have a good friend that picked up 3 tenths by switching from 600's to 660's that's my next direction but first gotta get rid of those 323's I ran it to 6600 in drive on the highway and it felt like i was holding onto a hand gernade!
Re: well im now in the tunnel ram club- i have a question [Re: W7_Scamp] #1183424
02/23/12 02:53 AM
02/23/12 02:53 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
is that indy intake only drilled for sideways mounted carbs?
Re: well im now in the tunnel ram club- i have a question [Re: sixpackgut] #1183425
02/23/12 09:58 AM
02/23/12 09:58 AM
Guitar Jones Offline
I didn't know there was a club. I use 2 Demon 750TR carbs on my 408 small block. I did have to match the two halves of the M1 TR too. My Demons are pretty much right out of the box with only jet and squirter changes. They work great but yeah I had to fix a few things on them like the stripped squirter screw holes and one of the base plates was assembled backwards.
Re: well im now in the tunnel ram club- i have a question [Re: W7_Scamp] #1183426
02/23/12 12:07 PM
02/23/12 12:07 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
440 2295S
fully ported stealth heads
comp solid 250 256 560 108
2 inch pro parts
TR with 2 650dps
ultimate 4500-4800
3.73s for now 4.30smax
electric wp alum rad etc. light as i can but keep my full interior
clovis had that exact cam with his TR and was 10.8s 124 i think?
Page 2 of 3 1 2 3
