Re: Starter doesn't always engage...
[Re: slowpoke]
#1183213
02/21/12 11:51 AM
02/21/12 11:51 AM
Posts: 632 MD-USA
Dodgeguy101
MD-USA
Brand new Jegs starter on my big block doesn't always engage. I have a thin shim on it and hope this is this is the problem but am not real confident. Anyone else have any experience with these starters?
Did you by chance use studs to bolt it on? Just throwing that out there, I did and the starter would sometimes not engage. Changed one of the studs to a bolt, moved the starter away from the block, only a hair, but it works fine now.
[Re: slowpoke]
#1183214
02/21/12 12:34 PM
02/21/12 12:34 PM
RapidRobert
What Dodge said, get a slight bit more seperation between the teeth
[Re: slowpoke]
#1183218
02/21/12 10:37 PM
02/21/12 10:37 PM
Posts: 632 MD-USA
Dodgeguy101
MD-USA
OEM 4 spd bell housing...
File a starter mounting hole out a little bit on the one side, I mean little, and hold the starter away from the engine while you tighten it up.
[Re: Dodgeguy101]
#1183219
02/21/12 10:38 PM
02/21/12 10:38 PM
Posts: 632 MD-USA
Dodgeguy101
MD-USA
Or spray some WD 40 on the flywheel teeth and see what happens.
