Locking out the advance ?
#1183083
02/20/12 10:32 PM
02/20/12 10:32 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
How many members on here are locking out the advance in there MSD distributors? I have been thinking that it would help my small block idle better with the timing higher at idle but the total timing would be the same. It idles alot better when I turn the timing up but then it is too high when it advances. It will see very little street miles.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Locking out the advance ?
[Re: D-50]
#1183085
02/20/12 10:50 PM
02/20/12 10:50 PM
Posts: 52,972 Romeo MI
MR_P_BODY
On one of my engines I have it locked but on the other 2 it has advance.... for yours you can put in a smaller advance button and advance the base more to give you the same total.... Myself I like the advance as long as it works well (not sticking and retards)
[Re: D-50]
#1183086
02/20/12 10:53 PM
02/20/12 10:53 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
Go for it. It will make everything better,,idle, throttle response, no timing lag/fluctuation. Make sure your battery is fully charged and your starter is in good shape and you will be good to go.Some have complained about kick back while starting. I have found that the battery or starter are usually causing those type problems. You can also wire the ignition to be turned on while spinning the motor if you want to run timing on the higher numbers.. Try it,,if you don't like it, you can always put it back the way it was..
If you like drag racing, support your local track.
[Re: D-50]
#1183088
02/20/12 11:56 PM
02/20/12 11:56 PM
Posts: 108 Wisconsin
MagnumExpress
Wisconsin
Lock it!!. You will like the results.
#9 in the world. 2006 IHRA Super Rod 2010 IHRA Div.5 Hot Rod Champion
[Re: MagnumExpress]
#1183089
02/21/12 01:57 AM
02/21/12 01:57 AM
Posts: 3,517 pacific northwest
Stroker Scamp
pacific northwest
mine locked out, one less thing to worry bout, no problems starting 32* 408 SB
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
[Re: Stroker Scamp]
#1183090
02/21/12 09:06 PM
02/21/12 09:06 PM
D-50
North, Alabama
Thanks for the reply's guys looks like I will be locking it out.Can not wait to try my new motor out. Test and Tune is March 17 ,maybe it will make it down the track. Thanks ...........
[Re: D-50]
#1183091
02/22/12 01:33 AM
02/22/12 01:33 AM
Posts: 4,207 New York
polyspheric
New York
When is locked better? When the previous setting was wrong.
Boffin Emeritus
[Re: polyspheric]
#1183092
03/02/12 08:03 PM
03/02/12 08:03 PM
D-50
North, Alabama
Thank you guys for the advice! I locked out the advance on my MSD distributor and it fires up instantly and idles great now. I even had to turn my idle screw down about 3/4 turn. It seems to have alot better throttle response. THANKS...Glenn
[Re: Thumperdart]
#1183097
03/04/12 04:45 PM
03/04/12 04:45 PM
D-50
North, Alabama
My timing is around 34* and so far I have not had to use my start retard.It has been starting fine also with 12.2 comp. Thanks....
[Re: D-50]
#1183098
03/05/12 03:48 AM
03/05/12 03:48 AM
Posts: 781 wine country
8urvette
wine country
i locked mine at 34, hard to start- 540 10-1 compression, big new battery and new mini starter. when i spun a rod bearing and disassembled i had massive cap walk (for a 50 mile engine). surprised me, maybe detonation??? maybe other issues...
[Re: 8urvette]
#1183099
03/05/12 10:53 AM
03/05/12 10:53 AM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I had my 14-1 416 motor locked at 35deg and had 0 problems with starting or anything else.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
