73 A body ps box in 70 satellite whats needed #1182209
02/19/12 05:46 PM
02/19/12 05:46 PM
kentucky
roadrunner7020 Offline OP
kentucky
The steering box in my 1970 satellite (roadrunner clone) has went out eventually i am to purchase a FF stage 3 box, however for now i have a 73 duster 340 sitting with a good ps box. I know the pitman arms are different diameters from 73 up, can i use the duster box and pitman arm with the rest of my steering linkage? Just looking for a cheap soultion for now until i can afford the FF box
Re: 73 A body ps box in 70 satellite whats needed [Re: roadrunner7020] #1182210
02/20/12 11:06 AM
02/20/12 11:06 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You have to buy a 73 B body pitman arm which is what you would probably have to use with the FF box, the A body arm will not work.
Re: 73 A body ps box in 70 satellite whats needed [Re: JohnRR] #1182211
02/20/12 11:56 AM
02/20/12 11:56 AM
kentucky
kentucky
So change box and pitman arms and my linkage will work?
Re: 73 A body ps box in 70 satellite whats needed [Re: roadrunner7020] #1182212
02/20/12 01:06 PM
02/20/12 01:06 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes , none of the other parts of the steering are different. I did it on a 68 satellite , changed to a cop box with the 73 arm the rest was stock parts.
Re: 73 A body ps box in 70 satellite whats needed [Re: JohnRR] #1182213
02/21/12 02:25 PM
02/21/12 02:25 PM
Cruising!
Q
QuickDodge Offline
QuickDodge  Offline
Q
Cruising!
So is it ONLY 73 B body pitmans that will work, or will any late B-body (73-78) pitman fit?
Re: 73 A body ps box in 70 satellite whats needed [Re: QuickDodge] #1182214
02/21/12 03:10 PM
02/21/12 03:10 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
73-78 + I think the last used box I grabbed was out of a 85 M body & it used the same arm...
Grabbed quite a bit off that one... 19K mile Cop Car.... Gave the roller 318 to a buddy...
Re: 73 A body ps box in 70 satellite whats needed [Re: 1_WILD_RT] #1182215
03/19/12 07:18 PM
03/19/12 07:18 PM
kentucky
kentucky
I was about to order the pitman arm today and on rock auto the 73 satellite arm is the same part number as the 73-76 duster.... my question is if this is true then why cant i just use the box and arm off the 73 duster i have?
Re: 73 A body ps box in 70 satellite whats needed [Re: roadrunner7020] #1182216
03/20/12 10:40 PM
03/20/12 10:40 PM
Mass
charge70 Offline
charge70  Offline
Mass
The Moog part# is K7076.This is the one you need to make a large shaft box work in a 70 B-Body.John.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: 73 A body ps box in 70 satellite whats needed [Re: charge70] #1182217
03/20/12 11:00 PM
03/20/12 11:00 PM
kentucky
kentucky
thanks for the part number! this is why i was/am confused
Re: 73 A body ps box in 70 satellite whats needed [Re: roadrunner7020] #1182218
03/21/12 01:42 AM
03/21/12 01:42 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
i didn't know it was the same as the A body arm , it didn't specifiy that in the article I read in Mopar action back in the late 80's/early 90's when I did the swap.
