How to get pushrod off of mastercylinder? #1182149
02/19/12 02:03 PM
02/19/12 02:03 PM
illinois
bigblk66_coronet Offline OP
illinois
Hey guys i have a 66 coronet with manual 4 wheel drum brakes. Im switching to a dual res M.C. and what i need to know is how the heck do i get the pushrod off of the old master cylinder? The new one didnt come with one! Not sure how to get it off but i dont want to screw it up! anyone? I need help fast!.......thanks joe
Re: How to get pushrod off of mastercylinder? [Re: bigblk66_coronet] #1182150
02/19/12 02:09 PM
02/19/12 02:09 PM
illinois
illinois
i have it out of the old mastercylinder but its the plunger on the end of the rod i cant get off!
Re: How to get pushrod off of mastercylinder? [Re: bigblk66_coronet] #1182151
02/19/12 02:09 PM
02/19/12 02:09 PM
IMGTX Offline
IMGTX  Offline
There is typically a rubber (sometimes metal) retainer.
I just yank the brake pedal up real hard and it usually pops it loose. Sometimes I loosen the MC and stick something behind it to move it away from the firewall if the pedal can not move far enough up.
If it is out of the car I lock the MC down in a vice. Stick a steel rod through the big end of the push rod and yank straight out.
Hope it helps.
Re: How to get pushrod off of mastercylinder? [Re: bigblk66_coronet] #1182152
02/19/12 02:11 PM
02/19/12 02:11 PM
IMGTX Offline
IMGTX  Offline
Oops.
Pace the plunger on a vice. Stick a steel rod in the big end of the push rod and yank.
Replace the plunger if it gets nicked.
Re: How to get pushrod off of mastercylinder? [Re: IMGTX] #1182153
02/19/12 02:24 PM
02/19/12 02:24 PM
illinois
illinois
Ive been tryin that exact thing and its not coming off! Thats thing is on there! And i use then new plunger with the new m.c. anyway right?....ill go try some more but i dont want to screw it up because then im really screwed!...lol
Re: How to get pushrod off of mastercylinder? [Re: bigblk66_coronet] #1182154
02/19/12 02:54 PM
02/19/12 02:54 PM
illinois
illinois
I think im just gonna have to cut the plunger off. That rod must be locked in there cause theres no was its coming off
Re: How to get pushrod off of mastercylinder? [Re: bigblk66_coronet] #1182155
02/19/12 03:19 PM
02/19/12 03:19 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
Before you cut the pushrod, apply heat to the stuck end. It will screw up the old master cylinder, but since you're not reusing it, so what. Heat will probably melt or otherwise loosen the rubber "O" ring on the pushrod so it can come out. Otherwise lock the pushrod in a vise and beat the crap out the mastercylinder with a BFH. I know they can be difficult, but it will come out. Also try soaking the pushrod cup with some thin oil { atf ] for a day or two before beating on it anymore.
Re: How to get pushrod off of mastercylinder? [Re: 5spdcuda] #1182156
02/19/12 03:55 PM
02/19/12 03:55 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Got a floor jack? Pull the saddle (The swiveling cup that raises) off your floor jack, drop the pushrod through the hole the rod will fit through but the master cylinder will not, insert a steel rod through the hole where the bolt attaching the pushrod to the brake pedal normally goes, the rod should pass below the frame of the floor jack.... Raise the floor jack.. The rod will pop out with enough force....
Re: How to get pushrod off of mastercylinder? [Re: bigblk66_coronet] #1182157
02/19/12 03:58 PM
02/19/12 03:58 PM
IMGTX Offline
IMGTX  Offline
I think Hugh is right. Get more violent.
Here is what you are fighting if Rick doesn't mind me stealing his pictures.
The groove in the pushrod snaps in the rubber ring which snaps in the back if the master cylinder.
Destroying the plunger is OK in your case since you are not reusing the Master Cylinder.
A flaming Wrench will work too.
Re: How to get pushrod off of mastercylinder? [Re: IMGTX] #1182158
02/19/12 07:44 PM
02/19/12 07:44 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Had exact same issue with my mc on my 70 sport satellite. The rubber had deteriorated to the point it was holding things tight. I ended up taking the piston out of the mc and the pushrod off the pedal. Put the pushrod in the vice, and wacked the piston with a hammer . . .
Re: How to get pushrod off of mastercylinder? [Re: bigblk66_coronet] #1182159
02/20/12 12:53 AM
02/20/12 12:53 AM
Canada
demon Offline
demon  Offline
Canada
easiest way is this. Undo the 4 nuts holding the master cylinder onto the firewall. Pull it away about 1/2-3/4 inch and stick a spacer or two behind. I use a couple small chunks of 1x4. Go in the car and yank the pedal up. Bingo. It's out! Just don't whack the brake light switch when you pull up on the pedal. And- always double check the brake light switch adjustment after installing the new masted cylinder so the brake lights come on when they should and aren't staying on
Re: How to get pushrod off of mastercylinder? [Re: 1_WILD_RT] #1182160
02/20/12 09:32 AM
02/20/12 09:32 AM
Richmond Va, KeislerTKO 60...
V
VanishPt Offline
VanishPt  Offline
V
floor jack works.
another method with the floor jack....put a long screw driver through the hole in the rod and put the shaft it horizontally under the floor jack, then hook and edge of the Mc mounting plate over the saddle and lift.. pops it right off.
Re: How to get pushrod off of mastercylinder? [Re: VanishPt] #1182161
02/20/12 04:04 PM
02/20/12 04:04 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
easyest way if still in car like they said, i unbolted mine moved it over to the side aginest studs and pulled pedal up
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
