Re: How to get pushrod off of mastercylinder?
[Re: bigblk66_coronet]
#1182152
02/19/12 02:11 PM
02/19/12 02:11 PM
Posts: 12,234 Looking for a way out of Middl...
IMGTX
i have it out of the old mastercylinder but its the plunger on the end of the rod i cant get off!
Oops.
Pace the plunger on a vice. Stick a steel rod in the big end of the push rod and yank.
Replace the plunger if it gets nicked.
[Re: 5spdcuda]
#1182156
02/19/12 03:55 PM
02/19/12 03:55 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Got a floor jack? Pull the saddle (The swiveling cup that raises) off your floor jack, drop the pushrod through the hole the rod will fit through but the master cylinder will not, insert a steel rod through the hole where the bolt attaching the pushrod to the brake pedal normally goes, the rod should pass below the frame of the floor jack.... Raise the floor jack.. The rod will pop out with enough force....
#1182157
02/19/12 03:58 PM
02/19/12 03:58 PM
IMGTX
I think Hugh is right. Get more violent. Here is what you are fighting if Rick doesn't mind me stealing his pictures. The groove in the pushrod snaps in the rubber ring which snaps in the back if the master cylinder. Destroying the plunger is OK in your case since you are not reusing the Master Cylinder. A flaming Wrench will work too.
#1182159
02/20/12 12:53 AM
02/20/12 12:53 AM
Posts: 1,179 Canada
demon
Canada
Hey guys i have a 66 coronet with manual 4 wheel drum brakes. Im switching to a dual res M.C. and what i need to know is how the heck do i get the pushrod off of the old master cylinder? The new one didnt come with one! Not sure how to get it off but i dont want to screw it up! anyone? I need help fast!.......thanks joe
easiest way is this. Undo the 4 nuts holding the master cylinder onto the firewall. Pull it away about 1/2-3/4 inch and stick a spacer or two behind. I use a couple small chunks of 1x4. Go in the car and yank the pedal up. Bingo. It's out! Just don't whack the brake light switch when you pull up on the pedal. And- always double check the brake light switch adjustment after installing the new masted cylinder so the brake lights come on when they should and aren't staying on
[Re: VanishPt]
#1182161
02/20/12 04:04 PM
02/20/12 04:04 PM
Posts: 1,606 westerly, ri. usa
440lebaron
westerly, ri. usa
easyest way if still in car like they said, i unbolted mine moved it over to the side aginest studs and pulled pedal up
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
