Oil Pump Gasket ???? #1182099
02/19/12 01:02 PM
02/19/12 01:02 PM
Out in Left Field, NY
bobs66440 Offline OP
I got a new oil pump but it didn't come with any gaskets and there is no o-ring(s) on the shaft or anywhere else. I have a Fel Pro engine gasket kit 2110 and it's not in there. There are 3 o-rings but I have no idea where they go. I need to know what gaskets I need and where they go. I assume maybe the small one goes on the pump shaft?
This is so frustrating...why wouldn't they include this gasket in the kit??? Makes no sense.
Where can I find a picture or description of where all the o-rings/gaskets go?
Can anyone help please? Sorry to sound so whiny, but thing like this drive me nuts!!
Thanks!
Re: Oil Pump Gasket ???? [Re: bobs66440] #1182100
02/19/12 01:06 PM
02/19/12 01:06 PM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
one of them will go on your distributer.
Re: Oil Pump Gasket [Re: bobs66440] #1182101
02/19/12 01:06 PM
02/19/12 01:06 PM
Posting from 1893 in NW FL
TheBlueBeast Offline
You are welcome.
Re: Oil Pump Gasket [Re: TheBlueBeast] #1182102
02/19/12 01:14 PM
02/19/12 01:14 PM
You are welcome.
Thank you!!
Re: Oil Pump Gasket [Re: bobs66440] #1182103
02/19/12 01:19 PM
02/19/12 01:19 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Here's a link to a photo of the oil pump.
http://t3.gstatic.com/images?q=tbn:ANd9GcSV4A6PcFHuu1W52yngAhbqqMihlfEQFZlYr9bkaQmW0FaUx_4N
Frankly, none of the o-rings in your photo look like oil pump o-rings but it's hard for me to judge.
Re: Oil Pump Gasket ???? [Re: bobs66440] #1182104
02/19/12 01:27 PM
02/19/12 01:27 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I agree that none of the o rings in pic look to be for oil pump. You need a skinnier small o ring for shaft that enters block, and you have to find the paper gasket that are sometimes absent in overhaul kits for some reason.
Re: Oil Pump Gasket ???? [Re: buildanother] #1182105
02/19/12 02:30 PM
02/19/12 02:30 PM
From what I understand, a gasket & o-ring are supposed to come with the pump, so I'm going to bring it back to Autozone and exchange it for one that has it...hopefully. It looks like the box was opened before, so somebody probably returned it and never put them back in.
Is there supposed to be an 0-ring between the block and the pump (in conjunction with the gasket)?
Thanks guys!
Re: Oil Pump Gasket ???? [Re: bobs66440] #1182106
02/19/12 02:49 PM
02/19/12 02:49 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Bob,
I stock that stuff here in Syracuse,,,drop me a note with your address and I'll throw a gasket in an envelope.
Todd Tuohey
Competition Wedge Engines
Syracuse, NY
RIP Monte Smith
Re: Oil Pump Gasket ???? [Re: bobs66440] #1182107
02/19/12 03:10 PM
02/19/12 03:10 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Thanks guys!
Do yourself a HUGE favor and completely disassemble the pump and d-burr all of the passages with a small dremel tool and completely clean it all in hot water then blow completely dry and re-assemble with assembly lube Never trust an oil pump out of the box
Gus
64 Plymouth Savoy
Dana 60
Re: Oil Pump Gasket ???? [Re: bobs66440] #1182108
02/19/12 03:47 PM
02/19/12 03:47 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
.....Is there supposed to be an 0-ring between the block and the pump (in conjunction with the gasket)?...
No.
Re: Oil Pump Gasket ???? [Re: 6PakBee] #1182109
02/19/12 09:59 PM
02/19/12 09:59 PM
No.
Thank you
Re: Oil Pump Gasket ???? [Re: CompWedgeEngines] #1182110
02/19/12 11:32 PM
02/19/12 11:32 PM
Bob,
Todd Tuohey
Syracuse, NY
PM sent
Re: Oil Pump Gasket ???? [Re: fourgearsavoy] #1182111
02/20/12 08:42 AM
02/20/12 08:42 AM
Thanks guys!
Gus
Thanks for the tip! Can I re-use the o-ring in the cover, because I don't have another?
