Oil Pump Gasket ????
#1182099
02/19/12 01:02 PM
02/19/12 01:02 PM
Posts: 1,880 Out in Left Field, NY
bobs66440
I got a new oil pump but it didn't come with any gaskets and there is no o-ring(s) on the shaft or anywhere else. I have a Fel Pro engine gasket kit 2110 and it's not in there. There are 3 o-rings but I have no idea where they go. I need to know what gaskets I need and where they go. I assume maybe the small one goes on the pump shaft? This is so frustrating...why wouldn't they include this gasket in the kit??? Makes no sense. Where can I find a picture or description of where all the o-rings/gaskets go? Can anyone help please? Sorry to sound so whiny, but thing like this drive me nuts!! Thanks!
Re: Oil Pump Gasket ????
[Re: bobs66440]
#1182106
02/19/12 02:49 PM
02/19/12 02:49 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Bob, I stock that stuff here in Syracuse,,,drop me a note with your address and I'll throw a gasket in an envelope. Todd Tuohey Competition Wedge Engines Syracuse, NY
RIP Monte Smith
[Re: 6PakBee]
#1182109
02/19/12 09:59 PM
02/19/12 09:59 PM
bobs66440
.....Is there supposed to be an 0-ring between the block and the pump (in conjunction with the gasket)?...
No.
Thank you
[Re: CompWedgeEngines]
#1182110
02/19/12 11:32 PM
02/19/12 11:32 PM
bobs66440
Bob,
PM sent
[Re: fourgearsavoy]
#1182111
02/20/12 08:42 AM
02/20/12 08:42 AM
bobs66440
From what I understand, a gasket & o-ring are supposed to come with the pump, so I'm going to bring it back to Autozone and exchange it for one that has it...hopefully. It looks like the box was opened before, so somebody probably returned it and never put them back in.
Thanks guys!
Do yourself a HUGE favor and completely disassemble the pump and d-burr all of the passages with a small dremel tool and completely clean it all in hot water then blow completely dry and re-assemble with assembly lube Never trust an oil pump out of the box Gus
Thanks for the tip! Can I re-use the o-ring in the cover, because I don't have another?
