What would be the cause? #1181753
02/18/12 09:09 PM
02/18/12 09:09 PM
Goodyear, AZ
Redleg Offline OP
Redleg  Offline OP
Goodyear, AZ
I pulled my pushrods to get to my lifters, thinking they were bad.... They all look flawless and brand new like they should, But, One of my Pushrods is bent and is Worn away like crazy.. the on next to it has a ring worn into it a little above the middle of it... and then one of the others has a ring worn into it but on the passenger side of the engine..
What am I look at as a culprit here... No more then 800 Miles on the engine. Pics to follow.
1977 D-150 Warlock 360/727
2021 Challenger T/A 392/M6
Its pronounced Dirte'
Re: What would be the cause? [Re: Redleg] #1181754
02/18/12 09:12 PM
02/18/12 09:12 PM
S.E.Mich
drew72 Offline
drew72  Offline
S.E.Mich
Holes in the head are too small. I am guessing you have a bit bigger than original camshaft. Clearance shoulda been checked at assembly. OOPS!
Re: What would be the cause? [Re: Redleg] #1181755
02/18/12 09:18 PM
02/18/12 09:18 PM
crlush Offline
crlush  Offline
pushrods not the right length = bad rocker arm gyometry, that would be my guess with the info you gave witch wasnt much. hydraulic, solid, adjustable rockerarms?
Re: What would be the cause? [Re: drew72] #1181756
02/18/12 09:19 PM
02/18/12 09:19 PM
Goodyear, AZ
Redleg Offline OP
Redleg  Offline OP
Goodyear, AZ
Hmmm, I was hoping it was something I could fix and not something a machine shop would need to, Hopefully the shop that built it will fit the bill.
Re: What would be the cause? [Re: Redleg] #1181757
02/18/12 09:22 PM
02/18/12 09:22 PM
Goodyear, AZ
Redleg Offline OP
Redleg  Offline OP
Goodyear, AZ
There non adjustable-Factorystyle Rockers. Melling Hydraulic Lifters and Melling Pushrods.
Re: What would be the cause? [Re: Redleg] #1181758
02/18/12 09:35 PM
02/18/12 09:35 PM
kalispell montana
jwilson 61 Offline
jwilson 61  Offline
kalispell montana
what engine and what heads??? year?
70 cuda 440 6bbl Auto with a dana 60
68 road runner QQ1 383 auto
1970 6 barrel 4 speed Superbird FY1 number matching
15 Challenger 6.4 SRT pearl White 6 Speed
72 Cuda 440 5 speed
71 Road Runner 440 4 speed
Re: What would be the cause? [Re: Redleg] #1181759
02/18/12 09:37 PM
02/18/12 09:37 PM
crlush Offline
crlush  Offline
is any of the other pushrods worn around in a circle like the one is? if not try another pushrod and see what happens.
Re: What would be the cause? [Re: crlush] #1181760
02/18/12 09:44 PM
02/18/12 09:44 PM
Goodyear, AZ
Redleg Offline OP
Redleg  Offline OP
Goodyear, AZ
Yeah two of the pushrods have the same ring in the same spots.
It's a 360LA with stock heads not sure of the year. Exhaust and intake lift on the cam are 480/480
Re: What would be the cause? [Re: Redleg] #1181761
02/18/12 10:20 PM
02/18/12 10:20 PM
scratchnfotraction Offline
looks like you have PR to head clearance issues.
some of the older heads have small PR holes that do not like roller lifters and shorter rods and need some grinding for clearance.
you can have the same clearance issue with any of them and should be checked on install.
look at the head in the PR hole to see where you need the grinding.you can do it yourself but the heads need to come off so no shavings are in the engine.
good luck at the machine shop
Re: What would be the cause? [Re: scratchnfotraction] #1181762
02/19/12 02:46 PM
02/19/12 02:46 PM
Goodyear, AZ
Redleg Offline OP
Redleg  Offline OP
Goodyear, AZ
Scratchin, Would I be using just a drill and bit to widen the holes? Also is it possible to make the holes to-big or is that a non issue?
Re: What would be the cause? [Re: Redleg] #1181763
02/19/12 02:53 PM
02/19/12 02:53 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I'd look close at all the rockers, that they are in correct order.
Re: What would be the cause? [Re: buildanother] #1181764
02/19/12 04:25 PM
02/19/12 04:25 PM
Goodyear, AZ
Redleg Offline OP
Redleg  Offline OP
Goodyear, AZ
what would be the correct order?
Re: What would be the cause? [Re: Redleg] #1181765
02/19/12 04:37 PM
02/19/12 04:37 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
If you look at the rocker arms the pushrod socket is offset slightly to the right or to the left.... If you look at the pushrod holes in the heads and their relationship to the rocker stands you'll see if assembled correctly the pushrods have clearance, if assembled incorrectly the pushrods are rubbing the sides of the holes... I couldn't find a picture showing proper assembly but I never used one to assemble rocker either, just look at what they need to do to work properly....
Re: What would be the cause? [Re: 1_WILD_RT] #1181766
02/19/12 05:39 PM
02/19/12 05:39 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
This might be helpful.
7079905-valvetrain.pdf (144 downloads)
