Polyurethane Upper Bushings Positive Caster Source? #1179814
02/17/12 10:11 AM
02/17/12 10:11 AM
eastern, pa.
cudabitten Offline OP
eastern, pa.
Hi, Can you purchase the positive caster upper control arm bushings in polyurethane? I also need lowers too, and strut bushings. I'd like to buy everything from one vender. 74 Barracuda.
Thanks,
Chris.
Re: Polyurethane Upper Bushings Positive Caster Source? [Re: cudabitten] #1179815
02/17/12 01:56 PM
02/17/12 01:56 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
No one makes a poly offset upper arm bushing. I have read that the rigidness of poly actually creates a bind with the pivot motion of the arm when they are made with an offset. The rubber offset bushings allow enough compliance for this to not be an issue.
Re: Polyurethane Upper Bushings Positive Caster Source? [Re: TC@HP2] #1179816
02/17/12 02:16 PM
02/17/12 02:16 PM
eastern, pa.
eastern, pa.
Thank you, that does make sense.
Re: Polyurethane Upper Bushings Positive Caster Source? [Re: cudabitten] #1179817
02/17/12 02:20 PM
02/17/12 02:20 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Re: Polyurethane Upper Bushings Positive Caster Source? [Re: OzHemi] #1179818
02/17/12 04:13 PM
02/17/12 04:13 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
I tried to find those pedders UCA bushings and NONE of the companies listed on pedders site were bothered enough to reply.
Re: Polyurethane Upper Bushings Positive Caster Source? [Re: RobX4406] #1179819
02/17/12 05:31 PM
02/17/12 05:31 PM
BDW Offline
BDW  Offline
At $120 plus shipping for those poly band-aids, you might be better off buying new UCAs
It's been 3-4yrs, but I only paid $200 for Just Suspension's UCA with ball joints and bushings installed.
Re: Polyurethane Upper Bushings Positive Caster Source? [Re: RobX4406] #1179820
02/17/12 05:56 PM
02/17/12 05:56 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
I just get my buddy to go a few miles down the road and grab them from the Pedders shop in Lilydale.
