Re: Challenger Valance attach/hardware
[Re: Publicbottle]
#1179666
02/18/12 03:50 AM
02/18/12 03:50 AM
Posts: 27,470 So Cal
autoxcuda
So Cal
Troy's old 30K mile 70 T/A. This rear valance had never been off before. Only pics I happen to catch of that.
You might want to pay Troy to burn you some disks of the couple thousand pictures he has of disassembling, restoring, and reassembling that car. The Barry Washington yellow T/A CD's are very helpfull too, but they don't show the car being taken apart and the bottom was fogged with paint once.
[Re: autoxcuda]
#1179667
02/18/12 03:53 AM
02/18/12 03:53 AM
autoxcuda
So Cal
[Re: slimert]
#1179673
02/22/12 03:39 PM
02/22/12 03:39 PM
Challenger 1
Cincinnati, Ohio
Had the same issues. Here are some correct fasteners.
That's my picture, glad it helped!
[Re: Challenger 1]
#1179674
02/22/12 03:54 PM
02/22/12 03:54 PM
Posts: 885 alberta
Publicbottle
alberta
hmmmmmmmmm optional brackets? my valance, which i found on ebay as a NOS piece for 70-71 does not have any additional brackets, i wonder if this was how some cars are? i seen a few other valances with the brackets, looks like they are welded to the back of the valance and then bolted to the crossmember?? thanks everyone for the input thus far!!!
[Re: Publicbottle]
#1179675
02/23/12 12:35 AM
02/23/12 12:35 AM
MoreParts
hmmmmmmmmm
Sounds like you may have a legit rear valance. I went threw getting these differentiated myself. Here's the old thread with some pics that may help clarifying for you.
https://board.moparts.org/ubbthreads/show...ID=#Post5971824
[Re: Publicbottle]
#1179676
02/23/12 03:13 AM
02/23/12 03:13 AM
autoxcuda
So Cal
hmmmmmmmmm
NOS and what was installed on the the assembly line are often two different things. Also NOS parts can change over the years they were produced for retail parts supply.
[Re: Publicbottle]
#1179677
02/23/12 09:28 AM
02/23/12 09:28 AM
Posts: 20 Dallas, PA
Eric_70_Chally
Dallas, PA
there is a kit available on ebay for about $20. i can't confirm the accuracy, but based on the photos in the above book, they appear correct (or damn close). i just got done 'pre-fitting' mine before i weld the quarters on and took some pictures detailing the outer attachment points. email me if you'd like a copy or i can post it in the forum. It, however, does not show correct hardware. cheers, eric eric.middleton1@gmail.com
1970 Challenger R/T U-Code (Restoration in process!)
[Re: Publicbottle]
#1179679
02/23/12 02:42 PM
02/23/12 02:42 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
hmmmmmmmmm
70 and 71 are not the same valence. 70 used brackets that were bolted to the car. 71 has the brackets as part of the valence.
