Challenger Valance attach/hardware #1179662
02/16/12 11:18 PM
02/16/12 11:18 PM
alberta
Publicbottle Offline OP
alberta
Does anyone have detailed pics on what hardware is used and where it goes to attach a rear valance?
Im havin problems and some pics would really clear things up. Appreciate the help!!
Re: Challenger Valance attach/hardware [Re: Publicbottle] #1179663
02/17/12 12:14 AM
02/17/12 12:14 AM
New State
kidmopar Offline
kidmopar  Offline
New State
What year
Re: Challenger Valance attach/hardware [Re: kidmopar] #1179664
02/17/12 01:42 AM
02/17/12 01:42 AM
alberta
alberta
ya that might be important! haha sorry...
1970 T/A
thanks
Re: Challenger Valance attach/hardware [Re: Publicbottle] #1179665
02/18/12 02:22 AM
02/18/12 02:22 AM
alberta
alberta
Re: Challenger Valance attach/hardware [Re: Publicbottle] #1179666
02/18/12 03:50 AM
02/18/12 03:50 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Troy's old 30K mile 70 T/A. This rear valance had never been off before. Only pics I happen to catch of that.
You might want to pay Troy to burn you some disks of the couple thousand pictures he has of disassembling, restoring, and reassembling that car. The Barry Washington yellow T/A CD's are very helpfull too, but they don't show the car being taken apart and the bottom was fogged with paint once.
Re: Challenger Valance attach/hardware [Re: autoxcuda] #1179667
02/18/12 03:53 AM
02/18/12 03:53 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
other side.
Re: Challenger Valance attach/hardware [Re: autoxcuda] #1179668
02/18/12 09:45 AM
02/18/12 09:45 AM
Virginia
V
varunner Offline
varunner  Offline
V
Virginia
Bottom 2 holes use studs and nuts with the integrated washers, top holes is a bolt with the same washer. all 10-24 threads.
Re: Challenger Valance attach/hardware [Re: varunner] #1179669
02/18/12 12:49 PM
02/18/12 12:49 PM
alberta
alberta
Thanks for the replies!! I do have Barrys yellow T/A cd, and is a great help most of the time, but it did not have detailed pics of the rear valance.
So, another question is, what are the holes along the top for, and the two brackets behind the license plate area, how are they fastened? are the studs and nuts too?
Re: Challenger Valance attach/hardware [Re: autoxcuda] #1179670
02/18/12 01:08 PM
02/18/12 01:08 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
1/4-20 double ended threaded studs go into U-shaped clips on the ends to attach it to quarters and are secured with captive washer nuts
10-24 hex head machine screws attach it to the 2 valance brackets on the bottom between the tips
10-24 machine screws ( could either be phillips head or hex head screws )
Re: Challenger Valance attach/hardware [Re: gtx6970] #1179671
02/18/12 07:44 PM
02/18/12 07:44 PM
Puyallup, Wa.
Steve340 Offline
Steve340  Offline
Puyallup, Wa.
Some early Challengers had an additional set of right angle brackets in between the ends and the large brackets. They were small and held just the top of the valance. My 1970 Challenger T/A had those but my friends 1970 Challenger T/A did not. It held the valance by those additional holes along the top. Maybe someone can post a picture of them since I don't have a picture and I don't have the car anymore.
Re: Challenger Valance attach/hardware [Re: Steve340] #1179672
02/22/12 03:07 PM
02/22/12 03:07 PM
WNY
slimert Offline
slimert  Offline
WNY
Had the same issues. Here are some correct fasteners.
Re: Challenger Valance attach/hardware [Re: slimert] #1179673
02/22/12 03:39 PM
02/22/12 03:39 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
That's my picture, glad it helped!
Re: Challenger Valance attach/hardware [Re: Challenger 1] #1179674
02/22/12 03:54 PM
02/22/12 03:54 PM
alberta
alberta
hmmmmmmmmm
optional brackets?
my valance, which i found on ebay as a NOS piece for 70-71 does not have any additional brackets, i wonder if this was how some cars are? i seen a few other valances with the brackets, looks like they are welded to the back of the valance and then bolted to the crossmember??
thanks everyone for the input thus far!!!
Re: Challenger Valance attach/hardware [Re: Publicbottle] #1179675
02/23/12 12:35 AM
02/23/12 12:35 AM
MoreParts Offline
MoreParts  Offline
hmmmmmmmmm
optional brackets?
Sounds like you may have a legit rear valance. I went threw getting these differentiated myself. Here's the old thread with some pics that may help clarifying for you.
https://board.moparts.org/ubbthreads/show...ID=#Post5971824
Re: Challenger Valance attach/hardware [Re: Publicbottle] #1179676
02/23/12 03:13 AM
02/23/12 03:13 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
hmmmmmmmmm
optional brackets?
NOS and what was installed on the the assembly line are often two different things. Also NOS parts can change over the years they were produced for retail parts supply.
Re: Challenger Valance attach/hardware [Re: Publicbottle] #1179677
02/23/12 09:28 AM
02/23/12 09:28 AM
Dallas, PA
E
Eric_70_Chally Offline
E
Dallas, PA
there is a kit available on ebay for about $20. i can't confirm the accuracy, but based on the photos in the above book, they appear correct (or damn close).
i just got done 'pre-fitting' mine before i weld the quarters on and took some pictures detailing the outer attachment points. email me if you'd like a copy or i can post it in the forum. It, however, does not show correct hardware.
cheers,
eric
eric.middleton1@gmail.com
1970 Challenger R/T U-Code (Restoration in process!)
Re: Challenger Valance attach/hardware [Re: Eric_70_Chally] #1179678
02/23/12 12:57 PM
02/23/12 12:57 PM
MoreParts Offline
MoreParts  Offline
I've got the kit in front of me. Yeah, it looks pretty close to those pics.
Re: Challenger Valance attach/hardware [Re: Publicbottle] #1179679
02/23/12 02:42 PM
02/23/12 02:42 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
hmmmmmmmmm
optional brackets?
70 and 71 are not the same valence. 70 used brackets that were bolted to the car. 71 has the brackets as part of the valence.
