Rod adjustment question for power brakes... #1179555
02/16/12 08:52 PM
02/16/12 08:52 PM
Missouri
bb74swngr Offline OP
mopar addict
mopar addict
Missouri
74 Dodge Dart. When installing the new master cylinder I checked to see if the booster push rod made contact with the piston in the new master cylinder. It was about 1/8" short of touching. Do I turn the adjusting tip out to touch the piston or leave it with the play? Thanks everyone!
BigBlock 74 Swinger
Re: Rod adjustment question for power brakes... [Re: bb74swngr] #1179556
02/16/12 08:58 PM
02/16/12 08:58 PM
Andrewh Offline
Andrewh  Offline
what I did was turn it out till it started to move the master and then dialed it back a little.
you can see a hole in the bottom of the master and see when the piston moves because of the rod.
otherwise the pedal will move without any resistance before brakes start to apply.
which will suprise anyone but you driving the car.
Re: Rod adjustment question for power brakes... [Re: Andrewh] #1179557
02/16/12 09:02 PM
02/16/12 09:02 PM
Missouri
mopar addict
mopar addict
Missouri
Should there be any pre-load on the piston or just have it touch without moving?
BigBlock 74 Swinger
Re: Rod adjustment question for power brakes... [Re: bb74swngr] #1179558
02/16/12 09:12 PM
02/16/12 09:12 PM
indiana
mcmopars Offline
mcmopars  Offline
indiana
i adjusted so it would not touch,just shy.brakes work as they should.
Re: Rod adjustment question for power brakes... [Re: mcmopars] #1179559
02/16/12 09:14 PM
02/16/12 09:14 PM
Missouri
mopar addict
mopar addict
Missouri
Thanks guys! I'm going to bring it up close and call it good:)
BigBlock 74 Swinger
