383 balance. #1179525
02/16/12 08:40 PM
02/16/12 08:40 PM
salem, oregon. usa
E
elmor Offline OP
elmor  Offline OP
E
salem, oregon. usa
Have a 71 383. It's apparently externally balanced. What is the difference between it and externally balanced 400's, 440's and 360's?
What can I use for a converter?
Re: 383 balance. [Re: elmor] #1179526
02/16/12 08:51 PM
02/16/12 08:51 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
check again
3IIRC all 383s were internally balanced..
I am truckless..
Re: 383 balance. [Re: 340SHORTY] #1179527
02/16/12 09:01 PM
02/16/12 09:01 PM
salem, oregon. usa
E
elmor Offline OP
elmor  Offline OP
E
salem, oregon. usa
Seems I remember that the 71's were the last 383's made and they were externally balanced. This one came with a weighted harmonic balancer like I have never seen. I've had 360's, 400's and 440's that were externally balanced, but this is different.
Re: 383 balance. [Re: elmor] #1179528
02/16/12 09:07 PM
02/16/12 09:07 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
Some 2 barrel 71's were externally balanced. Mine was an original 2 barrel with a forged crank (internally balanced).
Re: 383 balance. [Re: ireland383] #1179529
02/17/12 12:50 AM
02/17/12 12:50 AM
lewiston, ID
cornucopia Offline
cornucopia  Offline
lewiston, ID
yup. some 1971 383s were externally balanced. they had the CAST crank.
Re: 383 balance. [Re: elmor] #1179530
02/17/12 02:19 AM
02/17/12 02:19 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Then you need to use that balancer, the back end I have no idea but I assume it's close to the 400 ???
Re: 383 balance. [Re: JohnRR] #1179531
02/17/12 12:33 PM
02/17/12 12:33 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
someone said something naughty
Re: 383 balance. [Re: elmor] #1179532
02/17/12 01:49 PM
02/17/12 01:49 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
The 71 383 could have either if a two barrel motor.Damper is marked cast crank and engine I.D. pad will have the letter E on the pad.
Re: 383 balance. [Re: elmor] #1179533
02/17/12 03:58 PM
02/17/12 03:58 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
All cast crank big blocks take the same external weight, the 360 needs a much larger weight.
Re: 383 balance. [Re: John_Kunkel] #1179534
02/18/12 12:41 AM
02/18/12 12:41 AM
dogdays Offline
dogdays  Offline
yup.
R.
Re: 383 balance. [Re: John_Kunkel] #1179535
02/18/12 04:00 PM
02/18/12 04:00 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
actually 440 cast crank balancer it says FOR USE ONLY TO 440 CRANK or something like that
soooo
Re: 383 balance. [Re: NachoRT74] #1179536
02/18/12 04:01 PM
02/18/12 04:01 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Re: 383 balance. [Re: NachoRT74] #1179537
02/18/12 06:29 PM
02/18/12 06:29 PM
dogdays Offline
dogdays  Offline
Here's the conundrum: ALL cast crank B/RB engines used the SAME amount of factory imbalance, yet my 400 harmonic damper says "for 400 only" same as the 440 referred to above. Presumably there is a special 383 cast crank damper as well. YET, they have the same balance specs and can be interchanged no problem.
Chrysler was so intent on saving money they did a lot of weird things to save having two or three part numbers, yet here are three identical items with three castings. Bizarre.
Re: 383 balance. [Re: dogdays] #1179538
02/18/12 08:06 PM
02/18/12 08:06 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The subject in the OP is converters and "all cast crank big blocks take the same external weight".
Re: 383 balance. [Re: John_Kunkel] #1179539
02/20/12 02:05 AM
02/20/12 02:05 AM
dogdays Offline
dogdays  Offline
Here is the first line of the post:
"Have a 71 383. It's apparently externally balanced. What is the difference between it and externally balanced 400's, 440's and 360's?"
R.
Re: 383 balance. [Re: elmor] #1179540
02/20/12 11:09 AM
02/20/12 11:09 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Get the flex plate from B+M , assuming that they all use the same weighted converter, and then you can use ANY neutral balance converter your heart desires .
Re: 383 balance. [Re: dogdays] #1179541
02/20/12 06:25 PM
02/20/12 06:25 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
An engineer might disagree with the interchange notion; although the amount of imbalance is the same, the total mass of the inertia ring is probably deemed to be specific to one crank.
