Re: 383 balance.
[Re: elmor]
#1179526
02/16/12 08:51 PM
02/16/12 08:51 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
check again
3IIRC all 383s were internally balanced..
I am truckless..
Re: 383 balance.
[Re: elmor]
#1179530
02/17/12 02:19 AM
02/17/12 02:19 AM
Posts: 75,012 U.S.S.A.
JohnRR
U.S.S.A.
Seems I remember that the 71's were the last 383's made and they were externally balanced. This one came with a weighted harmonic balancer like I have never seen. I've had 360's, 400's and 440's that were externally balanced, but this is different.
Then you need to use that balancer, the back end I have no idea but I assume it's close to the 400 ???
Re: 383 balance.
[Re: elmor]
#1179533
02/17/12 03:58 PM
02/17/12 03:58 PM
Posts: 25,802 Rio Linda, CA
John_Kunkel
Rio Linda, CA
All cast crank big blocks take the same external weight, the 360 needs a much larger weight.
Re: 383 balance.
[Re: John_Kunkel]
#1179534
02/18/12 12:41 AM
02/18/12 12:41 AM
dogdays
Re: 383 balance.
[Re: dogdays]
#1179538
02/18/12 08:06 PM
02/18/12 08:06 PM
John_Kunkel
Rio Linda, CA
The subject in the OP is converters and "all cast crank big blocks take the same external weight".
Re: 383 balance.
[Re: elmor]
#1179540
02/20/12 11:09 AM
02/20/12 11:09 AM
JohnRR
U.S.S.A.
Have a 71 383. It's apparently externally balanced. What is the difference between it and externally balanced 400's, 440's and 360's? What can I use for a converter?
Get the flex plate from B+M , assuming that they all use the same weighted converter, and then you can use ANY neutral balance converter your heart desires .
