Mixing coolant-Dexcool and "Green Stuff" #1179103
02/15/12 11:25 PM
02/15/12 11:25 PM
alberta
Publicbottle Offline OP
alberta
Workin on a friends 98 blazer, need to change the rad due to a leak. I noticed that there is green coolant instead of the reccommended GM dexcool fluid.
I would rather not flush the whole system during the rad swap, so should i continue using green stuff or just mix in some Dexcool?
Thanks for your input!!
Re: Mixing coolant-Dexcool and "Green Stuff" [Re: Publicbottle] #1179104
02/15/12 11:42 PM
02/15/12 11:42 PM
Do not ever mix the red and green antifreezes together in the same system is what I have been told Those that have mixed them had to drain, flush and replace the mix with red stuff only or maybe green stuff only do to overheating issues with the mix
Re: Mixing coolant-Dexcool and "Green Stuff" [Re: Cab_Burge] #1179105
02/15/12 11:58 PM
02/15/12 11:58 PM
NW Indiana
deansrr Offline
deansrr  Offline
NW Indiana
with all the Dexcool problems, we never put it back in!!
1973 Road Runner 1974 Satellite (for sale) 1973 240z (wifes) 1993 Ramcharger (thanks Devil) 2002 Honda S2000
Re: Mixing coolant-Dexcool and "Green Stuff" [Re: Publicbottle] #1179106
02/16/12 12:04 AM
02/16/12 12:04 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Stay with the green stuff!!
Re: Mixing coolant-Dexcool and "Green Stuff" [Re: Challenger 1] #1179107
02/16/12 06:06 AM
02/16/12 06:06 AM
W. Sacto CA. USA
P
phantomx Offline
phantomx  Offline
P
W. Sacto CA. USA
We mixed a cup of green with a cup of dex at work years ago when the dex was just coming out. The dex clumped up into funky coagulated fluffy crap that floated around. It looked like it would plug up a radiator in a hurry. I would just flush it and drain the block and use one or the other.
Travis..
70 GTX project, orig 440-4, 4 spd, track pack, FC7, stripper/street racer special.
Re: Mixing coolant-Dexcool and "Green Stuff" [Re: phantomx] #1179108
02/16/12 07:24 AM
02/16/12 07:24 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Dex is the worst crap ever made.Leave the green in.We used pretty much nothing but the new Universal stuff at work.Probally did a few thousand with no problems.We only put Dex back in if the customer insisted we did.Rocky
Chrysler Firepower
Re: Mixing coolant-Dexcool and "Green Stuff" [Re: therocks] #1179109
02/16/12 09:49 AM
02/16/12 09:49 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
you could try some of the newer yellow universal antifreeze. it says on the label it will mix with all coolants.
perception is 90% of reality
Re: Mixing coolant-Dexcool and "Green Stuff" [Re: Mr T2U] #1179110
02/16/12 09:56 AM
02/16/12 09:56 AM
Cincinnati, Ohio
Cincinnati, Ohio
Why would he do that? There's green in there now.
Re: Mixing coolant-Dexcool and "Green Stuff" [Re: Challenger 1] #1179111
02/16/12 10:22 AM
02/16/12 10:22 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
DON'T MIX> unless your are using a universal anti freeze that mixes with either. It works well with not problems.
Re: Mixing coolant-Dexcool and "Green Stuff" [Re: MoparforLife] #1179112
02/16/12 10:42 AM
02/16/12 10:42 AM
SE Pa.
LimeliteAero Offline
SE Pa.
as mentioned dont mix the different products.
I lost a supercharged Pontiac 3.8 in my wifes 99 Grand Prix when my brother in law was helping us out and topped her coolant off when he was changing her oil.
Re: Mixing coolant-Dexcool and "Green Stuff" [Re: LimeliteAero] #1179113
02/16/12 11:03 AM
02/16/12 11:03 AM
Somebody was already proactive & switched from dexcool to regular green. As said top it off w green & you're good
Re: Mixing coolant-Dexcool and "Green Stuff" [Re: RapidRobert] #1179114
02/16/12 11:25 AM
02/16/12 11:25 AM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
Add me to the get that dexcool garbage out of there .
Re: Mixing coolant-Dexcool and "Green Stuff" [Re: JohnRR] #1179115
02/16/12 02:20 PM
02/16/12 02:20 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
What do you guys this of the DEX-COOL approved Prestone stuff? Thats what I've used in my Lumina. Its pink like the DEX-COOL.
Re: Mixing coolant-Dexcool and "Green Stuff" [Re: LimeliteAero] #1179116
02/16/12 03:16 PM
02/16/12 03:16 PM
Alaska
73rrak Offline
73rrak  Offline
Alaska
Wally world ( Walmart ) screwed up my wife's van a few years ago by putting green anti freeze in a dex cool system. They topped it off after an oil change. The over flow tank looked like it was full of mud. She had to have the cooling system flushed and it had the rear heater system so it cost around $400. Of course she lost her receipt from Wally World so we got stuck paying for it because wally world wouldn't step up to the plate and take responsibility for it without a receipt.
Re: Mixing coolant-Dexcool and "Green Stuff" [Re: Publicbottle] #1179117
02/16/12 05:56 PM
02/16/12 05:56 PM
Missouri
MY340 Offline
MY340  Offline
Missouri
We own three GM vehicles which use Dex-Cool coolant and have never had any cooling problem issues.
Don't mix of course like everyone states.
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Re: Mixing coolant-Dexcool and "Green Stuff" [Re: 73rrak] #1179118
02/16/12 06:22 PM
02/16/12 06:22 PM
N.W. Florida
Fat_Mike Online work
Fat_Mike  Online Work
N.W. Florida
If you mix them, this "mud" type substance WILL be the result. If you already have the dexcool, take the jug out in the woods and shoot it (or take it back for a refund).
Re: Mixing coolant-Dexcool and "Green Stuff" [Re: Cab_Burge] #1179119
02/16/12 11:23 PM
02/16/12 11:23 PM
alberta
alberta
Wow, thanks for all the replies!
Will stick with the green stuff!!
