R5P7 IN A A-BODY QUESTIONS... #1178914
02/15/12 06:27 PM
02/15/12 06:27 PM
SO CAL
BB70DUSTER Offline OP
SO CAL
Whats it take to put a R5 P7 engine in a Duster? Obviously headers and a motorplate, but what trans pattern are they? I have a tubular K member with lots of room for a big pan... anybody have pics? I know a few memebers have made the swap... Whats the weight difference from a RB Mopar??? Thanks in advance...
Re: R5P7 IN A A-BODY QUESTIONS... [Re: BB70DUSTER] #1178915
02/15/12 06:29 PM
02/15/12 06:29 PM
Arizona
Chris'sBarracuda Offline
Arizona
Mike..
PM.. R5P7Duster on here.. Title explains it all..
Chris..
Re: R5P7 IN A A-BODY QUESTIONS... [Re: Chris'sBarracuda] #1178916
02/15/12 06:51 PM
02/15/12 06:51 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
There are various adapters available, as the R5 has their own bell housing pattern. Depending on what crank is in the engine, some have a Ford, some have a chevy crank flange. If you haven't done so already, buy a complete engine, something out of the Busch Cup (the roller cam engines with the 390 Carb) rather than the flat tappet Nascar engine. There were several variations with the Rockers etc over the years, making up an engine out of parts can prove difficult.
The are a few members on the board that run these combo's, so hopefully the rest chime in for you. I need a memory refresh on some of the stuff for when my engine arrives.
Alan Jones
Re: R5P7 IN A A-BODY QUESTIONS... [Re: LA360] #1178917
02/15/12 10:48 PM
02/15/12 10:48 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
The crank flange is either symetrical 6 or 8 bolt. BOBSPROFAB makes and adapter. If the crank is 6 bolt you will convert to a MOPAR 6 bolt. If it is 8 bolt you convert to a MOPAR 8 bolt.
Bob also makes a adapter plate that has attachement ears to make a custom motor plate with it.
Leon
Re: R5P7 IN A A-BODY QUESTIONS... [Re: Leon441] #1178918
02/16/12 12:15 PM
02/16/12 12:15 PM
SO CAL
SO CAL
Leon
What would I do If I wanted to back it with a glide?
Re: R5P7 IN A A-BODY QUESTIONS... [Re: BB70DUSTER] #1178919
02/16/12 06:17 PM
02/16/12 06:17 PM
LA360 Offline
LA360  Offline
You would need an adapter to suit the GM pattern firstly, the find a suitable flexplate. It's been so long since I really got into these engines, I am abit hazy on some of the details, so I will leave it for someone else to chime in.
Alan Jones
Re: R5P7 IN A A-BODY QUESTIONS... [Re: BB70DUSTER] #1178920
02/16/12 09:13 PM
02/16/12 09:13 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
Bob made mine, I went to small block 727 bolt patern so i could use more bolts.
Call Bob, he will give you all the answers to your questions.
Very nice guy
Re: R5P7 IN A A-BODY QUESTIONS... [Re: B1KILLER] #1178921
02/16/12 09:14 PM
02/16/12 09:14 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
Re: R5P7 IN A A-BODY QUESTIONS... [Re: BB70DUSTER] #1178922
02/16/12 09:17 PM
02/16/12 09:17 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Remember those r5's are a dry sump setup.
Re: R5P7 IN A A-BODY QUESTIONS... [Re: BB70DUSTER] #1178923
02/16/12 09:42 PM
02/16/12 09:42 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
i am not 100% sure,but i think that little motor is WIDER then a big block
Re: R5P7 IN A A-BODY QUESTIONS... [Re: fishy340] #1178924
02/17/12 09:54 AM
02/17/12 09:54 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Yes they are a hair wider than a RB at the heads. You will not be able to put the engine in the stock location without modifying the k frame. You won't be able to get it to sit down far enough. I make adapter plate kits as well. Mine are behind everything from sand drag rails in Ohio to speed boats in Australia and many drag cars internationally. If you have any other questions feel free to PM me here or ask in this forum and I will try to keep and eye on this thread
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: R5P7 IN A A-BODY QUESTIONS... [Re: Leon441] #1178925
02/17/12 02:05 PM
02/17/12 02:05 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Leon
This is not 100% correct. There are 2 6 bolt styles. One is the Chevy 6 (symmetrical) and the Ford 6 has one hole not equal spaced..
SDG Motorsports
Re: R5P7 IN A A-BODY QUESTIONS... [Re: BB70DUSTER] #1178926
02/17/12 02:08 PM
02/17/12 02:08 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
]What would I do If I wanted to back it with a glide?
First off you'd have to get a reverse chevy bell or just get a SB Chrysler bell since you are changing bells. Cause there is no where to mount a starter on a glide, the starter bolts to the block on a chevy. Then depending on which bell you decide to get you have to get torque convertor and flywheel/flex plate to match.
SDG Motorsports
