Time slips. #1178320
02/14/12 03:15 PM
02/14/12 03:15 PM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
Since its still winter here in Md and kinda slow I figured everyone could post their timeslips and the combo if they like. I enjoy looking at cars and how they 60 ft and mph for the combo. Here is my best et so far with my new pump gas full ehx street car. You cand see my new combo if you click the link as its the latest build at the bottom of the page. Thanks , Ron
http://www.1962to1965mopar.ornocar.com/mmo82008.html
Re: Time slips. [Re: 383man] #1178321
02/14/12 03:31 PM
02/14/12 03:31 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
avg of 3 slips. then the build.
1969 Sport Satellite,rear seat/heaterbox is out,8pt cage[ms],glass hood and the rest is factory body 3650#.i have a dana 60/4.10spool 29.5/10.5 MT,moser axles 35 spline,ww 4 wheel disc with hyd hand e brake 4 piston on rear[custom bracket 2 caliper]3800# ss springs,rancho 9 way shocks,ms 3.5" driveshaft w/solid u joints,727 PTC 9.5 5k stall,chetah rmvb,A&A drum n planets,ENGINE:koleno perf RB 4.35 bore/wiseco ,3.75 stroke/440 source,eagle H 2k bolts,factory 346 heads port/polish 95cc chamber 2.14int@280cfm/1.81 exh @180cfm HS 1.5 rockers,comp 3/8 pushrods,SDC copper head gaskets .090 o-ring block reciever in heads,BDS intake,blowershop 8-71 @ 10% OD,2x1250 holley 80532-1 carbs pvs blocked 110 jets still tunning,BG 400 pump,MSD 7-AL2 ign,pro coil,FIRECORE 50 wires,NGK-8 plugs .025/.030,10.14/136 spinning 60'[2.0+60']hooker 2" x34 headers.
Re: Time slips. [Re: 383man] #1178322
02/14/12 04:17 PM
02/14/12 04:17 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
Nice slips!
I'm totally jealous.
Re: Time slips. [Re: 383man] #1178323
02/14/12 04:22 PM
02/14/12 04:22 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
My timeslip looks alot like yours
60' 1.49
330' 4.330
1/8 6.747
mph 101.65
1000' 8.845
1/4 10.635
mph 125.04
I was gonna put r/t .248
My timeslips are so light they dont scan
67' charger 499 RB 10.57 at 127
Re: Time slips. [Re: 383man] #1178324
02/14/12 09:25 PM
02/14/12 09:25 PM
Regina Sask, Canada
V
Viper469 Offline
Viper469  Offline
V
Regina Sask, Canada
Here's a couple of mine...
Right lane.
Left lane.
Re: Time slips. [Re: Viper469] #1178325
02/14/12 11:09 PM
02/14/12 11:09 PM
Port Alberni, British Columbia
MoparDonny Offline
MoparDonny  Offline
Nothing too special here but what the heck
Re: Time slips. [Re: MoparDonny] #1178326
02/15/12 03:43 AM
02/15/12 03:43 AM
Finland
mopar396 Offline
mopar396  Offline
Finland
MOPAR OR NO CAR
Re: Time slips. [Re: mopar396] #1178327
02/15/12 04:17 AM
02/15/12 04:17 AM
Arizona
Chris'sBarracuda Offline
Arizona
Looks like a turbo time slip, 130mph 1/8th to 174+mph 1/4..
Picking up 44mph.. on the back half..
I think Al's S/ST car does that on the stop..
Chris..
Re: Time slips. [Re: Chris'sBarracuda] #1178328
02/15/12 10:33 AM
02/15/12 10:33 AM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
My best. Was in Norwalk and time sure flys. The last time I ran the car was in fall of 08' I made 1 run, all year and haven't been back since
Re: Time slips. [Re: Bigcube] #1178329
02/15/12 11:02 AM
02/15/12 11:02 AM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
This is my 'favorite' slip..
If you like drag racing, support your local track.
Re: Time slips. [Re: 383man] #1178330
02/15/12 12:02 PM
02/15/12 12:02 PM
Owego, NY
JBurch Offline
JBurch  Offline
Owego, NY
65 Barracuda, .030 over 360, internal balance, Hughes stageIII Eddy heads, MP557 cam, M1 intake, CRT race prep 904, PTC 5000 stall converter, 4.88 gears, Cal-Tracks, mono leafs, M/Y 275x15/60 drag radials.
I'm in the left lane
Re: Time slips. [Re: 383man] #1178331
02/15/12 12:36 PM
02/15/12 12:36 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
'99 Dakota, 4190#
.030 over stock block 360, single turbo, M1 2bbl, F&B 50mm TB, mild cam, 3.92 gears, Detroit Locker.... needs more suspension work. I am working on the 60'.
M86 on the right on a hail-mary pass just to see what kind of potential it has with race gas... spinning 1st and 2nd.
Re: Time slips. [Re: Duner] #1178332
02/15/12 12:45 PM
02/15/12 12:45 PM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
Ok I'll play since I just posted it elsewhere but here is one of mine.
Re: Time slips. [Re: Al_Alguire] #1178333
02/15/12 01:48 PM
02/15/12 01:48 PM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
Al is that the new silver Cuda that you are painting ? I mean it looks like its at least a mid 8 car with that mph ? Do you mind a brief rundown on the combo as I forgot and it sure is one bad boy. Ron
Re: Time slips. [Re: Duner] #1178334
02/15/12 01:51 PM
02/15/12 01:51 PM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
'99 Dakota, 4190#
I know turbo cars always mph more then NA but thats low 10 mph. Ron
Re: Time slips. [Re: 383man] #1178335
02/15/12 03:50 PM
02/15/12 03:50 PM
Arizona
Arizona
Ron..
That's his Super Street car..
What a ride.. I think that's about 4.5 seconds on the stop..
Chris..
Re: Time slips. [Re: Chris'sBarracuda] #1178336
02/15/12 03:59 PM
02/15/12 03:59 PM
South Jersey, NJ
DragDart360 Offline
DragDart360  Offline
South Jersey, NJ
As posted in my sig. Heddman Husler 1 7/8 tube headers and 1050 Dominator ready to install
70 Dart Swinger, 2850 lbs
SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
Re: Time slips. [Re: 383man] #1178337
02/15/12 04:06 PM
02/15/12 04:06 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
I can't help but think life would be easier if I could just knock the weight down... but I really like my AC and stereo.
Re: Time slips. [Re: Duner] #1178338
02/15/12 05:42 PM
02/15/12 05:42 PM
Las Vegas
Las Vegas
Ron as Chris said that is my S/ST car.It has run a best of 8.04 at 169 all out. But it is not set up to run that way after all I am a stop racer.
Dont have a timeslip for the other car scanned. We have been 8.40 at 165 so far with 12 degrees of timing out of it for 1.5 seconds in 3000' DA air. That is at close to 3400lbs on a true 10.5" tire with a killer 1.300 60' time. We hope in good air like we should get next month to greatly improve that number
Re: Time slips. [Re: Al_Alguire] #1178339
02/15/12 05:44 PM
02/15/12 05:44 PM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
Al is it a Hemi car NA or another eng with a power adder ? Thanks , Ron
