Re: Time slips.
[Re: 383man]
#1178321
02/14/12 03:31 PM
02/14/12 03:31 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
avg of 3 slips. then the build. 1969 Sport Satellite,rear seat/heaterbox is out,8pt cage[ms],glass hood and the rest is factory body 3650#.i have a dana 60/4.10spool 29.5/10.5 MT,moser axles 35 spline,ww 4 wheel disc with hyd hand e brake 4 piston on rear[custom bracket 2 caliper]3800# ss springs,rancho 9 way shocks,ms 3.5" driveshaft w/solid u joints,727 PTC 9.5 5k stall,chetah rmvb,A&A drum n planets,ENGINE:koleno perf RB 4.35 bore/wiseco ,3.75 stroke/440 source,eagle H 2k bolts,factory 346 heads port/polish 95cc chamber 2.14int@280cfm/1.81 exh @180cfm HS 1.5 rockers,comp 3/8 pushrods,SDC copper head gaskets .090 o-ring block reciever in heads,BDS intake,blowershop 8-71 @ 10% OD,2x1250 holley 80532-1 carbs pvs blocked 110 jets still tunning,BG 400 pump,MSD 7-AL2 ign,pro coil,FIRECORE 50 wires,NGK-8 plugs .025/.030,10.14/136 spinning 60'[2.0+60']hooker 2" x34 headers.
Re: Time slips.
[Re: Bigcube]
#1178329
02/15/12 11:02 AM
02/15/12 11:02 AM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
This is my 'favorite' slip..
If you like drag racing, support your local track.
Re: Time slips.
[Re: 383man]
#1178330
02/15/12 12:02 PM
02/15/12 12:02 PM
Posts: 644 Owego, NY
JBurch
Owego, NY
65 Barracuda, .030 over 360, internal balance, Hughes stageIII Eddy heads, MP557 cam, M1 intake, CRT race prep 904, PTC 5000 stall converter, 4.88 gears, Cal-Tracks, mono leafs, M/Y 275x15/60 drag radials.
I'm in the left lane
Re: Time slips.
[Re: 383man]
#1178331
02/15/12 12:36 PM
02/15/12 12:36 PM
Posts: 1,969 Chandler, AZ
Duner
Chandler, AZ
'99 Dakota, 4190# .030 over stock block 360, single turbo, M1 2bbl, F&B 50mm TB, mild cam, 3.92 gears, Detroit Locker.... needs more suspension work. I am working on the 60'. M86 on the right on a hail-mary pass just to see what kind of potential it has with race gas... spinning 1st and 2nd.
Re: Time slips.
[Re: Duner]
#1178334
02/15/12 01:51 PM
02/15/12 01:51 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I know turbo cars always mph more then NA but thats low 10 mph. Ron
Re: Time slips.
[Re: 383man]
#1178335
02/15/12 03:50 PM
02/15/12 03:50 PM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
Al is that the new silver Cuda that you are painting ? I mean it looks like its at least a mid 8 car with that mph ? Do you mind a brief rundown on the combo as I forgot and it sure is one bad boy. Ron
Ron..
That's his Super Street car..
What a ride.. I think that's about 4.5 seconds on the stop..
Chris..
Re: Time slips.
[Re: Duner]
#1178338
02/15/12 05:42 PM
02/15/12 05:42 PM
Posts: 19,372 Las Vegas
Al_Alguire
Las Vegas
Ron as Chris said that is my S/ST car.It has run a best of 8.04 at 169 all out. But it is not set up to run that way after all I am a stop racer. Dont have a timeslip for the other car scanned. We have been 8.40 at 165 so far with 12 degrees of timing out of it for 1.5 seconds in 3000' DA air. That is at close to 3400lbs on a true 10.5" tire with a killer 1.300 60' time. We hope in good air like we should get next month to greatly improve that number
