Re: Crooked engine?
[Re: Junky]
#117775
09/09/08 10:42 AM
09/09/08 10:42 AM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
As long as it's straight in the frame, as in parallel to the frame rails, it's correct. They did it for more steering box clearance, and more room in the drivers footwell area.
Free advice and worth every penny... Factory trained Slinky rewinder.........
Re: Crooked engine?
[Re: RodStRace]
#117777
09/09/08 11:03 AM
09/09/08 11:03 AM
I thought it was to make sure the drive shaft was angled so the ujoints wouldnt burn out
Re: Crooked engine?
[Re: RodStRace]
#117778
09/09/08 11:15 AM
09/09/08 11:15 AM
Posts: 2,826 NY usa
540challenger
NY usa
the motor should be offset evenly, not angled. Tell all your Brand X buddies that Ma Mopar did it to offset the driver's weight, making the car handle better!
thats a good one i using that a the next car show.
Re: Crooked engine?
[Re: cudarex]
#117782
09/09/08 03:03 PM
09/09/08 03:03 PM
Posts: 5,186 Wherever I am.
Junky
Wherever I am.
He's saying the motor is not parallel to the frame rails.
Exactly. The front of the engine is more toward the passenger side...cooked...not parallel to the frame rails.
Re: Crooked engine?
[Re: Junky]
#117784
09/09/08 03:07 PM
09/09/08 03:07 PM
Posts: 1,134 OHIO THE HEART OF IT ALL
64hemi330sedan
MY 65 DOES THAT TOO.IT HAS THE STOCK K-MEMBER AND TRANS MOUNT. AND I DONT MEAN OFFSET TO THE RIGHT.ITS CROOKED BETWEEN THE FRAME RAILS.
Re: Crooked engine?
[Re: Junky]
#117785
09/09/08 04:10 PM
09/09/08 04:10 PM
Posts: 288 Birmingham, England
Mick70RR
Birmingham, England
I once fitted the transmission mount back to front and it did the same thing. Make sure yours is fitted the right way and the transmission tailshaft is centred in the tunnel.
1970 Road Runner
505 cid
MCH CNC ported Stealth heads
MP 528 camshaft
4 speed
GV overdrive
11.98 @ 117 on street treads
