Crooked engine? #117770
09/09/08 10:20 AM
09/09/08 10:20 AM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
Why is the V8 engine in my '65 Coronet crooked, or offset to one side in the front if you will? By offset I mean the front of the engine is further to the passenger side than the rear of the engine. Are all older ('60's) Mopars this way? How much is the offset? I've been asked these questions, but can't answer them.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: Crooked engine? [Re: Junky] #117771
09/09/08 10:22 AM
09/09/08 10:22 AM
Andrewh Offline
Andrewh  Offline
It is my understanding that all early b's are offset like that. You can also see the rad brackets are off set as well so it is not closer on one side or the other.
Re: Crooked engine? [Re: Andrewh] #117772
09/09/08 10:24 AM
09/09/08 10:24 AM
Odessa, Tx.
cudarex Offline
cudarex  Offline
Odessa, Tx.
Why would Mopar do that?
Re: Crooked engine? [Re: Junky] #117773
09/09/08 10:25 AM
09/09/08 10:25 AM
NY usa
540challenger Offline
NY usa
All the mopars i worked on are like that 71 challenge,r 73 cuda, 69 roadrunner, 68 charger, and a 69 newport to name a few
Re: Crooked engine? [Re: cudarex] #117774
09/09/08 10:26 AM
09/09/08 10:26 AM
Gillett, Pa
3404speed Offline
3404speed  Offline
Gillett, Pa
Clearance for steering box. IIRC
Re: Crooked engine? [Re: Junky] #117775
09/09/08 10:42 AM
09/09/08 10:42 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
As long as it's straight in the frame, as in parallel to the frame rails, it's correct. They did it for more steering box clearance, and more room in the drivers footwell area.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Crooked engine? [Re: Evil Spirit] #117776
09/09/08 10:52 AM
09/09/08 10:52 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
the motor should be offset evenly, not angled.
Tell all your Brand X buddies that Ma Mopar did it to offset the driver's weight, making the car handle better!
Re: Crooked engine? [Re: RodStRace] #117777
09/09/08 11:03 AM
09/09/08 11:03 AM
I thought it was to make sure the drive shaft was angled so the ujoints wouldnt burn out
Re: Crooked engine? [Re: RodStRace] #117778
09/09/08 11:15 AM
09/09/08 11:15 AM
NY usa
NY usa
thats a good one i using that a the next car show.
Re: Crooked engine? [Re: 540challenger] #117779
09/09/08 11:25 AM
09/09/08 11:25 AM
Andrewh Offline
Andrewh  Offline
actually I am pretty sure it is angled. Not sure anymore which side, but one of the brackets for the rad is deeper than the other so the fan is parallel.
Re: Crooked engine? [Re: Junky] #117780
09/09/08 02:41 PM
09/09/08 02:41 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
its not just the older Mopars, My 96 V8 Dakota is offset to clear the steering..
Re: Crooked engine? [Re: Dakota_Don] #117781
09/09/08 02:48 PM
09/09/08 02:48 PM
Odessa, Tx.
cudarex Offline
cudarex  Offline
Odessa, Tx.
He's saying the motor is not parallel to the frame rails.
Re: Crooked engine? [Re: cudarex] #117782
09/09/08 03:03 PM
09/09/08 03:03 PM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
Exactly. The front of the engine is more toward the passenger side...cooked...not parallel to the frame rails.
Re: Crooked engine? [Re: Junky] #117783
09/09/08 03:05 PM
09/09/08 03:05 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
check your motor mounts.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Crooked engine? [Re: Junky] #117784
09/09/08 03:07 PM
09/09/08 03:07 PM
OHIO THE HEART OF IT ALL
64hemi330sedan Offline
MY 65 DOES THAT TOO.IT HAS THE STOCK K-MEMBER AND TRANS MOUNT. AND I DONT MEAN OFFSET TO THE RIGHT.ITS CROOKED BETWEEN THE FRAME RAILS.
Re: Crooked engine? [Re: Junky] #117785
09/09/08 04:10 PM
09/09/08 04:10 PM
Birmingham, England
Mick70RR Offline
Mick70RR  Offline
Birmingham, England
I once fitted the transmission mount back to front and it did the same thing. Make sure yours is fitted the right way and the transmission tailshaft is centred in the tunnel.
1970 Road Runner 505 cid MCH CNC ported Stealth heads MP 528 camshaft 4 speed GV overdrive 11.98 @ 117 on street treads
Re: Crooked engine? [Re: Mick70RR] #117786
09/09/08 05:25 PM
09/09/08 05:25 PM
Western Michigan
68Fastback Offline
68Fastback  Offline
Western Michigan
Could be all the mounts as stated or the rear end has broken the locating pin and the torque is just doing its thing.
Re: Crooked engine? [Re: 68Fastback] #117787
09/09/08 05:41 PM
09/09/08 05:41 PM
Andrewh Offline
Andrewh  Offline
again, no, that is how they are built.
The radiator mouting brackets are factory set up so one side is deeper than the other so the fan is parallel to the rad since the engine is cocked.
Re: Crooked engine? [Re: 68Fastback] #117788
09/09/08 05:41 PM
09/09/08 05:41 PM
Odessa, Tx.
cudarex Offline
cudarex  Offline
Odessa, Tx.
My motor got out of sink like that when my stock tranny mount went bad.
Re: Crooked engine? [Re: cudarex] #117789
09/09/08 07:27 PM
09/09/08 07:27 PM
Outside
thedriver Offline
thedriver  Offline
Outside
i've been askin my motor why its so crooked fer years....it hasnt given me an answer....but it keeps takin all my money!
1973 challenger
Dana. 4 speed. Low deck.
