Cleaning a plastic fan shroud #1177732
02/13/12 03:39 PM
02/13/12 03:39 PM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
I recently picked up an original plastic fan shroud for my car. It is in great shape but needs a good cleaning. I tried washing it and scrubbing it with a brush but the dirt on it is like baked on. Does anyone know what I could use to clean the dirt off without damaging the surface of the shroud?
Re: Cleaning a plastic fan shroud [Re: 1970RT] #1177733
02/13/12 03:46 PM
02/13/12 03:46 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Chrome Wheel cleaner.... It's an acid formula & will loosen all sorts of stuff... Since acid is stored in a plastic bottle it obviously doesn't effect plastic...
Re: Cleaning a plastic fan shroud [Re: 1_WILD_RT] #1177734
02/13/12 05:53 PM
02/13/12 05:53 PM
Sonora, CA
68X426 Offline
68X426  Offline
Sonora, CA
Not all plastics are the same, "plastic" is a very broad category. Best to not assume that the storage bottle is the same material in the shroud. The bottle has different requirements for its job than a shroud.
Try Simple Green first. Amd then maybe a pressure washer.
The 12 Scariest Words in the English Language: We are here from the Government and we want to help you. 1968 Plymouth Road Runner, Hemi and much more 1968 Dodge Charger, 318 and not much else 1958 Dodge Pick Up, 383 and loud 1966 Dodge Van, Slant 6 and cool
Re: Cleaning a plastic fan shroud [Re: 68X426] #1177735
02/13/12 06:19 PM
02/13/12 06:19 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
In the order I do them
simple green
laquer thinner
glass bead cabinet
laquer thinner
adhesion promotor
SEMS satin black
Re: Cleaning a plastic fan shroud [Re: gtx6970] #1177736
02/13/12 08:58 PM
02/13/12 08:58 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I've used wax & grease remover and Simple Green, then some Armor-All. I prefer to not paint them, but I can understand that sometimes there's no other way to make them nice.
Re: Cleaning a plastic fan shroud [Re: 1970RT] #1177737
02/13/12 09:22 PM
02/13/12 09:22 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I blasted the plactic stuff that comes on challengers with a pressure washer. It did a great job for me and I did't do anything to them afterwards except spray WD 40 on them.
They still look good today.
Re: Cleaning a plastic fan shroud [Re: Challenger 1] #1177738
02/13/12 09:34 PM
02/13/12 09:34 PM
IN
ahy Offline
ahy  Offline
IN
Simple Green and a pressure washer has worked well for me on plastic chassis parts like the shroud. On somewhat nasty under car parts like rail mounted splash shields I have used a light coat of Krylon semi flat black which seems to hold up well. I wouldn't do that on a shroud as it might just flake and look crummy... if needed I'd use the 3 step SEM plastic paint process (cleaner, adhesive promoting primer wash, black finish coat).
Re: Cleaning a plastic fan shroud [Re: ahy] #1177739
02/13/12 11:49 PM
02/13/12 11:49 PM
SE Pa.
LimeliteAero Offline
SE Pa.
another vote for Simple Green...
Re: Cleaning a plastic fan shroud [Re: LimeliteAero] #1177740
02/14/12 12:33 AM
02/14/12 12:33 AM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
If you don't mind spending some coin.....contact these guys.
Thier product works great for fan shourd restorations.
http://www.restorationfullcircle.com/index.html
Re: Cleaning a plastic fan shroud [Re: 67vertman] #1177741
02/14/12 02:00 AM
02/14/12 02:00 AM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
I gave mine a good cleaning with Simple Green and then shot it with a Krylon Fusion (for plastics) spray bomb. Surprised how good it looks--maybe a little glossier than stock. No flaking.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Cleaning a plastic fan shroud [Re: wingman] #1177742
02/14/12 10:10 AM
02/14/12 10:10 AM
Franklin Co. Illinois
runinonmt Offline
runinonmt  Offline
Foaming tire cleaner (No Touch),brush,rinse,dry then your favorite protectant. The original on my '75 looks like new.
Ron
In sixty-five I was seventeen and running up one-o-one I don't know where I'm running now, I'm just running on Jackson Browne-Running On Empty
