Big Block engine books #1177459
02/12/12 10:02 PM
02/12/12 10:02 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
Any opinions on good Big block performance engine building books?
Re: Big Block engine books [Re: flatiron] #1177460
02/12/12 10:22 PM
02/12/12 10:22 PM
USA
hudsonhornet7x Offline
USA
By far the best book I have read is Andy F's book " How to build Max Performance Mopar Big Blocks".
In my opinion that book should be first on the list. Read it and absorb the knowledge!
Re: Big Block engine books [Re: flatiron] #1177461
02/12/12 10:59 PM
02/12/12 10:59 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
X2 also order the B-body performance book both from Mancini Racing and have them both in a few days
Gus
64 Plymouth Savoy
Dana 60
Re: Big Block engine books [Re: hudsonhornet7x] #1177462
02/12/12 11:01 PM
02/12/12 11:01 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
and im a sb only guy,i bought Andys and its pretty damn cool.
Re: Big Block engine books [Re: fishy340] #1177463
02/12/12 11:30 PM
02/12/12 11:30 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have Andy's book also and it is the best I have seen. The good thing is it is the most modern that I have seen with many up to date aluminum heads used and many real dyno runs he did to tell you what works good. Its the best if you want to build a big block wedge stroker. Ron
Re: Big Block engine books [Re: flatiron] #1177464
02/13/12 12:54 PM
02/13/12 12:54 PM
AndyF Offline
AndyF  Offline
Tom has a book section here on Moparts. If you buy the books from his page then Moparts gets a little bit of the action. That way you help fund the site.
http://www.moparts.org/moparts/books/index.html
Re: Big Block engine books [Re: AndyF] #1177465
02/13/12 02:46 PM
02/13/12 02:46 PM
USA
DAK512 Offline
DAK512  Offline
USA
Andy's book gets 2 from me
Re: Big Block engine books [Re: AndyF] #1177466
02/13/12 06:56 PM
02/13/12 06:56 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
I clicked on the site and then clicked on the book and Amazon .com came up if I buy from here does Moparts get a cut? I don't buy much off line
