where to find radial slicks #1176702
02/11/12 09:30 PM
02/11/12 09:30 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
also dumb question, when running a radial slick do they expand in height during a burnout. I know drag radials dont wondering if the slicks dont either.
Looking for 28X10X15 or 27X10X15
Thank you
Kiddart
Re: where to find radial slicks [Re: Kiddart] #1176703
02/11/12 10:47 PM
02/11/12 10:47 PM
PA
Belvedere500ci Offline
PA
Mine don't.. I have about a finger width(maybe less) between front of the tire and the rocker.. They haven't hit in hundreds of runs.. I'm not aware of them making any less than a 30x9 tho.. If you can fit them, try them.. Hoosiers are what I run.. What a difference from the Quick time pro 27x10.5 DOT and the 30x9 radial slick..
1967 Plymouth Belvedere II 383
1968 Plymouth Barracuda 383
2005 Ram 3500 5.9Diesel
1979 Dodge Power Wagon 360
Re: where to find radial slicks [Re: Belvedere500ci] #1176704
02/12/12 01:23 AM
02/12/12 01:23 AM
Bend, Oregon
67cuda340 Offline
super street
67cuda340  Offline
super street
Bend, Oregon
HEY you stole my car!
I am also thinking of changing to a drag slick.
What is your setup engine..etc Is your hood fiberglass who makes it?
Matt
1973 Dodge Dart Sport 360 Drag radials 12.30 1/4 mile 7.82 1/8 mile
Re: where to find radial slicks [Re: 67cuda340] #1176705
02/12/12 03:32 AM
02/12/12 03:32 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I use the Hoosier 30 x 9 radial slicks and I like them. I even drive on the street with them and they actually handle nice. Ron
Re: where to find radial slicks [Re: 383man] #1176706
02/12/12 10:38 AM
02/12/12 10:38 AM
Sullivan, Ohio
Max Wedge Savoy Offline
Sullivan, Ohio
You need some more air in those tires Ron. I run mine at 22-23psi. Ask your Hoosier rep about seeing wrinkles on radials.
Re: where to find radial slicks [Re: Max Wedge Savoy] #1176707
02/12/12 11:39 AM
02/12/12 11:39 AM
Locomotion Offline
Locomotion  Offline
I've also been running Hoosier radial slicks on my car. Because they don't grow any significant amount like bias ply, you will see higher rpm's at the finish line if using the same size tire. They should be run at higher pressures than bias ply. I found 21 lbs on a 10" rim to work best for my particular combo. You may also feel a firmer "snap" off the line and your RT's may get a bit quicker. ET's should be faster as well - .05-.10 are typical. *** The only downside to radial slicks is that they are more sensitive to track conditions. If the track surface is "marginal", a radial slick will spin sooner and longer than a bias ply under the same conditions. I run them all the time because I don't like to change the car or my routine if I ran bias ply and had a heads-up run. Fortunately, track prep has been very good at the IHRA events I attend. But I have had some consistency problems at local bracket races.
Hoosier has a wide range of radial and bias ply slicks to choose from.
Hoosier drag race tires.
Contact your closest distributor for dealer locations:
Hoosier distributor map.
Well, I couldn't get the distributor link to work right, but this is the closest distributor to Michigan:
Hoosier Tire Midwest- Plymouth
1801 Jim Neu Drive
Plymouth, IN 46563
Phone (574) 936-8344
Fax (574) 936-1673
E-mail: hoosiertireply@aim.com
Re: where to find radial slicks [Re: Max Wedge Savoy] #1176708
02/12/12 02:10 PM
02/12/12 02:10 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Actually thats the wrong pic as that is the Hoosier QTP tires I used to use in that pic. This is the radial slicks. Ron
