98 Dodge Ram Missing? #1176517
02/11/12 01:41 PM
02/11/12 01:41 PM
Ohio
ScottG Offline OP
ScottG  Offline OP
Ohio
Hey guys, I have a 98 Dodge Ram 5.2 with 122,000 miles on it. When I am going around 55 mph in overdrive and press on the gas to speed up the truck seems to start missing. When I am out of overdrive it does not do it. Like today driving into the wind, at around 45 mph and then pressing on the gas litely to get to 55 it starts to miss bad. But if I am out of overdrive at a higher rpm and try the same thing no miss. Any ideas?
Thanks Scott!
1966 Coronet 440 conv. original Mauve metallic, with white top and interior. 1971 360, J heads, 625 AFB, 340 cam, intake, and manifolds. With 3.23 SureGrip.
1969 Dart GT: B5 Blue, White top, 318, With A/C
Re: 98 Dodge Ram Missing? [Re: ScottG] #1176518
02/11/12 03:11 PM
02/11/12 03:11 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Whens the last time you did a tune up and cleaned the throttle body.
Re: 98 Dodge Ram Missing? [Re: stumpy] #1176519
02/11/12 03:15 PM
02/11/12 03:15 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
I saw the thread title and thought your truck had been stolen!
It's Swifty! Swifty, you toad sucker!
Re: 98 Dodge Ram Missing? [Re: ScottG] #1176520
02/11/12 05:09 PM
02/11/12 05:09 PM
crlush Offline
crlush  Offline
when mine started doing that all it needed was a tuneup.
Re: 98 Dodge Ram Missing? [Re: crlush] #1176521
02/11/12 05:52 PM
02/11/12 05:52 PM
Ohio
ScottG Offline OP
ScottG  Offline OP
Ohio
Wow when I read the thread title I can see where you would think it was stolen. That made me laugh. What would have to be done for a tune up. I just put new plugs in it. What else should be looked at?
Thanks Scott
Re: 98 Dodge Ram Missing? [Re: ScottG] #1176522
02/11/12 06:19 PM
02/11/12 06:19 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
If wires are originals, I would change them. They can do strange break down symptoms like that.
Re: 98 Dodge Ram Missing? [Re: buildanother] #1176523
02/11/12 07:38 PM
02/11/12 07:38 PM
St Paul MN
73swinger Offline
73swinger  Offline
St Paul MN
I agree with plug wires. may want to check routing, and that none of them touch.
I also put tubing around the coil wire on mine.
Chris Schwartz 73 Swinger 340 12.451 @ 108.78 73 Gold Duster, needs a plan.
Re: 98 Dodge Ram Missing? [Re: 73swinger] #1176524
02/11/12 11:01 PM
02/11/12 11:01 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Re: 98 Dodge Ram Missing? [Re: mopars4ever] #1176525
02/12/12 11:54 AM
02/12/12 11:54 AM
Ohio
ScottG Offline OP
ScottG  Offline OP
Ohio
Thanks so much for the info. I will give it a try.
Scott
