98 Dodge Ram Missing?
#1176517
02/11/12 01:41 PM
02/11/12 01:41 PM
Posts: 259 Ohio
ScottG
Ohio
Hey guys, I have a 98 Dodge Ram 5.2 with 122,000 miles on it. When I am going around 55 mph in overdrive and press on the gas to speed up the truck seems to start missing. When I am out of overdrive it does not do it. Like today driving into the wind, at around 45 mph and then pressing on the gas litely to get to 55 it starts to miss bad. But if I am out of overdrive at a higher rpm and try the same thing no miss. Any ideas?
Thanks Scott!
1966 Coronet 440 conv. original Mauve metallic, with white top and interior. 1971 360, J heads, 625 AFB, 340 cam, intake, and manifolds. With 3.23 SureGrip.
1969 Dart GT: B5 Blue, White top, 318, With A/C
Re: 98 Dodge Ram Missing?
[Re: crlush]
#1176521
02/11/12 05:52 PM
02/11/12 05:52 PM
Posts: 259 Ohio
ScottG
Ohio
Wow when I read the thread title I can see where you would think it was stolen. That made me laugh. What would have to be done for a tune up. I just put new plugs in it. What else should be looked at?
Thanks Scott
[Re: buildanother]
#1176523
02/11/12 07:38 PM
02/11/12 07:38 PM
Posts: 864 St Paul MN
73swinger
St Paul MN
I agree with plug wires. may want to check routing, and that none of them touch. I also put tubing around the coil wire on mine.
Chris Schwartz
73 Swinger 340 12.451 @ 108.78
73 Gold Duster, needs a plan.
[Re: 73swinger]
#1176524
02/11/12 11:01 PM
02/11/12 11:01 PM
Posts: 13,615 md
mopars4ever
md
[Re: mopars4ever]
#1176525
02/12/12 11:54 AM
02/12/12 11:54 AM
Posts: 259 Ohio
ScottG
Ohio
Thanks so much for the info. I will give it a try.
Scott
