You guys ever have a converter that wouldn't seat? #1176179
02/10/12 07:47 PM
02/10/12 07:47 PM
Mansfield, Tx
Jacob Pitt Offline OP
Mansfield, Tx
I have a fresh trans (904) and a brand new Ultimate converter but as far as I can get the converter down there just isn't any clearance with the flex plate. With the converter down as far as it will go there is only .400" from the bell housing to the converter bolt lugs. I have stabbed plenty of converters in my day and never had a problem. It hits two sets of splines and won't go down any further. Any ideas?
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: You guys ever have a converter that wouldn't seat? [Re: Jacob Pitt] #1176180
02/10/12 08:05 PM
02/10/12 08:05 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
are the lugs the same thickness as ur old converter?? try some vasiline on the end of the hub & see if contacts the support. something to try, seeya.
Re: You guys ever have a converter that wouldn't seat? [Re: Jacob Pitt] #1176181
02/10/12 08:25 PM
02/10/12 08:25 PM
mississippi
bentwheel43 Offline
bentwheel43  Offline
mississippi
I did that too,broke the ears off the pump.It needs 3 clicks to get it in.I think mine was about .400 then a click and it went.Thats the frist time i broke it.
Section 8 Racing We are nuts about racing.
Re: You guys ever have a converter that wouldn't seat? [Re: Jacob Pitt] #1176182
02/10/12 08:35 PM
02/10/12 08:35 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
If you have help and can stand the trans on end, just spin the converter and it will drop from gravity. My Dad taught me that trick years ago.
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: You guys ever have a converter that wouldn't seat? [Re: I_bleed_MOPAR] #1176183
02/10/12 08:36 PM
02/10/12 08:36 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
EYEBALL the pump tangs ... they are probably way-off.
Re: You guys ever have a converter that wouldn't seat? [Re: dOc !] #1176184
02/10/12 09:17 PM
02/10/12 09:17 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
Might also check the tangs or tabs on the front pump. I had one that was really tough and turned out the tabs were a bit chewed and made the conv hard to stab.Once I replaced the pump gears everthing went fine.
Re: You guys ever have a converter that wouldn't seat? [Re: DavidDean] #1176185
02/10/12 09:24 PM
02/10/12 09:24 PM
Riverside, California
Lil Demon Offline
Lil Demon  Offline
You don't even want me to rehash my converter saga.
Re: You guys ever have a converter that wouldn't seat? [Re: Lil Demon] #1176186
02/10/12 10:11 PM
02/10/12 10:11 PM
Mansfield, Tx
Mansfield, Tx
Everything looks good and the tags are turning but it won't go all the way down. I have tried putting it on its tail and spinning the converter just can't get it to fall.
14x Track Champ
Re: You guys ever have a converter that wouldn't seat? [Re: Jacob Pitt] #1176187
02/10/12 10:37 PM
02/10/12 10:37 PM
Las Vegas NV
moparmanjames Offline
Las Vegas NV
I sometimes have to clean up the splines on the input shaft with a file, especially with TCI stuff.
Re: You guys ever have a converter that wouldn't seat? [Re: Jacob Pitt] #1176188
02/10/12 10:37 PM
02/10/12 10:37 PM
Ambridge, Pa.
Ambridge, Pa.
i would put the support, take drive gear & see if it slips on the hub. if it does, i would then check out the splines on input shaft & stator shaft. seeya.
Re: You guys ever have a converter that wouldn't seat? [Re: Jacob Pitt] #1176189
02/10/12 11:51 PM
02/10/12 11:51 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I had trouble getting my 727 converter to seat.
My problem was the max lug pump gear did not have a chamfer on the converter side so it hitting the converter and not centering. Took the pump apart, and put a slight chamfer of the gear and it finally went together correctly.
Re: You guys ever have a converter that wouldn't seat? [Re: 451Mopar] #1176190
02/11/12 12:45 AM
02/11/12 12:45 AM
Mansfield, Tx
Mansfield, Tx
Thanks guys. Got my local tranny guy coming over tomorrow to check it out.
14x Track Champ
Re: You guys ever have a converter that wouldn't seat? [Re: Jacob Pitt] #1176191
02/11/12 01:53 AM
02/11/12 01:53 AM
Amarillo, Texas
red70duster Offline
red70duster  Offline
Amarillo, Texas
Have you measured the length of the snout? I had a new convertor for a 727 that had the wrong snout on it. I finally checked it against my old one and found it was too long. They had used a snout that was designed for a specialized application not a standard length. Just saying might be worth a look.
Re: You guys ever have a converter that wouldn't seat? [Re: red70duster] #1176192
02/12/12 02:15 PM
02/12/12 02:15 PM
Mansfield, Tx
Mansfield, Tx
I found some burrs on the stator that I took a file to and cleaned up all the splines and got the converter on another .060" and got everything put together and fired up yesterday. Thanks for all the suggestions.
14x Track Champ
Re: You guys ever have a converter that wouldn't seat? [Re: Jacob Pitt] #1176193
02/12/12 04:21 PM
02/12/12 04:21 PM
Ambridge, Pa.
Ambridge, Pa.
always something stupid.
